Roland AdvancedJET AJ-1000 Logo
A
Anonymous Posted on Jan 27, 2014
AJ 1000 Sevice call 0152 - Roland AdvancedJET AJ-1000
My Vizio tv main board 3647-0152-01502D is bad. Can I replace it with 3647-0152-01502G? 0171-2272-2782 & VO47L120F1A is printed on both.
You may try, by the part number, they should be the same board with a efferent EEPROM firmware version.
2005 dodge ram 1500 hemi. will set code 0132 when starting only some times. O2 replaced both sides.
Try changing the coolant temp sensor, it determines when the ECU shifts from open loop (cold) to closed loop(hot)
Need tv library codes to connect universal media so xbox media re
Aiko 0047
Aiwa 0433, 0247, 0247, 0433, 0446
Akai 0044
Amtron 0038
Anam 0248, 0038, 0071, 0116, 0122
AOC 0005, 0022, 0050, 0062, 0126
Apex 0119, 0141, 0155, 0438
Audiovox 0038
Bell & Howell 0008, 0043
Benq 0227, 0198
Broksonic 0133, 0134, 0248
Celebrity 0044
Citizen 0005, 0038, 0047, 0055, 0062, 0085, 0156
Colortyme 0005, 0013, 0062
Contec/Cony 0248, 0016, 0019, 0038
Craig 0038, 0248
Crown 0038, 0063
Curtis Mathes 0005, 0664, 0043, 0053, 0062, 0085, 0152, 0156
Daewoo 0005, 0017, 0047, 0050, 0062, 0103, 0146, 0156, 0486, 0237
Daytron 0005, 0062, 0156
Dimensia 0664, 0152
Dumont 0001, 0005
Durabrand 0439
Electroband 0044
Electrohome 0005, 0037, 0044, 0062, 0066, 0071
Emerson 0005, 0011, 0012, 0014, 0015, 0016, 0020, 0021, 0035, 0038, 0043, 0052, 0056, 0062, 0069, 0124, 0129, 0137, 0156, 0248, 0486
Envision 0005, 0062
Fisher 0025, 0040, 0043, 0115, 0245
Fujitsu 0015, 0199, 0200, 0201, 0202, 0203, 0669
Funai 0015, 0038, 0248
Gateway 0207
GE 0664, 0005, 0018, 0032, 0037, 0059, 0062, 0071, 0074, 0104, 0147, 0152, 0248, 0469, 0488, 0489
Goldstar 0005, 0016, 0023, 0045, 0050, 0062, 0066, 0077, 0096, 0143, 0156, 0249
Hallmark 0005, 0062
Hisense 0125
Hitachi 0003, 0005, 0016, 0019, 0030, 0060, 0062, 0064, 0067, 0081, 0095, 0101, 0106, 0124, 0136, 0213, 0238, 0473, 0496, 0173, 0174, 0175, 0412, 0165, 0171, 0205
Infinity 0063
Janeil 0120
JBL 0063
JC Penney 0005, 0018, 0019, 0032, 0037, 0664, 0041, 0045, 0050, 0055, 0062, 0074, 0077, 0085, 0102, 0104, 0143, 0152, 0156, 0249
Jensen 0005, 0062
JVC 217, 0435, 0010, 0016, 0019, 0024, 0033, 0051, 0056, 0060, 0074, 0132, 0142, 0217, 0435, 0470, 0475, 0477, 0497, 0503, 0504, 0505, 0216
Kawasho 0005, 0044, 0062
Kenwood 0005, 0062, 0066
Kloss Novabeam 0036, 0038, 0042, 0120
KTV 0038, 0080, 0137, 0156, 0248
LG 0050
Loewe 0063
Logik 0008
Luxman 0005, 0062
LXI 0664, 0041, 0043, 0062, 0063, 0104, 0117, 0152, 0249
Magnavox 0521, 0005, 0027, 0029, 0034, 0036, 0042, 0055, 0062, 0063, 0066, 0097, 0098, 0222, 0522, 0523, 0524
Majestic 0008
Marantz 0005, 0048, 0062, 0063, 0064, 0249
Megatron 0062, 0064
Memorex 0008, 0043, 0050, 0062, 0249, 0442, 0525
MGA 0005, 0025, 0026, 0037, 0050, 0062, 0066, 0076
Mitsubishi 0005, 0025, 0026, 0037, 0049, 0050, 0062, 0066, 0076, 0223, 0526, 0527, 0666
Montgomery Ward 0008
Motorola 0071, 0110
MTC 0005, 0050, 0062, 0085
Multitech 0038
Multivision 0070
NAD 0041, 0062, 0106
NEC 0005, 0013, 0050, 0062, 0071
NET-TV 0163, 0192
Nikko 0047, 0062
Onwa 0038, 0248
Optimus 0106
Optonica 0054, 0110
Orion 0012, 0129, 0441
Panasonic 0135, 0150, 0215, 0063, 0071, 0074, 0127, 0135, 0150, 0215, 0528, 0530, 0566, 0228, 0228, 0170, 0179, 0180, 0211
Philco 0005, 0016, 0027, 0029, 0036, 0042, 0050, 0055, 0062, 0063, 0066, 0071
Philips 0005, 0016, 0027, 0032, 0036, 0042, 0046, 0055, 0063, 0066, 0071, 0214, 0235, 0299, 0540, 0541, 0543, 0545, 0548, 0550, 0553, 0554, 0522, 0560, 0562
Philips Magnavox 0413, 0299, 0413, 0521, 0540, 0545, 0548, 0550, 0552, 0553, 0554, 0522, 0524, 0523, 0560, 0562
Pioneer 0005, 0062, 0068, 0072, 0075, 0106, 0124, 0408, 0411, 0197, 0158
PlasmaSync 0169
Portland 0005, 0047, 0050, 0062, 0156
Price Club 0085
Prima 0139
Prism 0074
Proscan 0664, 0104, 0152
Proton 0005, 0016, 0062, 0065, 0249
Quasar 0071, 0074, 0080, 0127, 0228, 0565, 0566
Radio Shack 0043, 0152, 0248
Radio Shack/Realistic 005, 0016, 0038, 0664, 0043, 0054, 0062, 0143, 0156
RCA 0436, 0664, 0153, 0664, 0005, 0022, 0050, 0062, 0066, 0071, 0087, 0092, 0094, 0100, 0104, 0107, 0109, 0118, 0124, 0130, 0146, 0152, 0153, 0248, 0436, 0568, 0488, 0486
Runco 0001
Sampo 0005, 0062, 0138, 0143, 0156, 0163
Samsung 0005, 0016, 0050, 0053, 0062, 0066, 0085, 0093, 0102, 0114, 0143, 0156, 0231, 0401, 0184, 0177, 0210, 0159, 0160, 0208, 0406, 0181, 0182, 0183, 0184, 0185, 0193, 0665
Sansui 0131, 0129, 0131, 0441
1helpful
What are the valve clearence specifications on a 2001 yamaha yz 426f?
1/1000 inch : inlet= 6-8 cold exaust= 10-12 cold. hope this gets u outta trouble AJ.
2answers
Need to find a replacement motor for my auto pilot pump. it is a CE M81120 motor. Any idea where i might be able to purchase one? Thanks Aj
as far as i know, the electric motor is not available. Replace it with a Furuno or Simrad pump (Acusteer) and you will have a sevice-able item.
Can i rebuild sprint steering damper myself
What kind of steering dumper is that? What brand?
If it uses gas chamber you cannot fill it yourself.If it is only with oil you can rebuilt it but you need some tools (depends on the brand) and if you can find a sevice manual it would be a lot better (to know how much oil to put inside and parts that you may need).
Need a Manual
try this link , but you have to register , dont worry its free , hope you can find your manual here.
good luck AJ
http://kitchen.manualsonline.com/manuals/mfg/black_decker/black_decker_electric_steamer_product_list.html?s=fpw
Panasonic AJ-D230H DV/Mini DV VCR
in the past I used a place called robbs repair; however they charged from 1000 to 2500 dollars to repair a machine that was only worth 3000.
So thats when I decided to bring the service of our 230's and 255's in house..
I have 15 years of electronics engineering experience and alot of that focused in broacast audio and video.
I am getting set up in a new building to do this as a business now: I used to be a TV station engineer but decided I try making a business of this.
I have experience completely refubishing the 230 and 255 models.
I have already coordinated with an electronics assembly house and got excellant pricing quotations for the sevice of replacing all of the capacitors on the boards in the unit that go stale after 5000 to 8000 hours of use ...
This is only one of the major problems the all dvc's encounter:
reel motors, captsans and elevator\ejector assemblies, cleaning rollers and pinch rollers all need replacement for a complete refurb.
500 bucks for a complete recapping, and a quote would have to be provided for the replacement of the other parts based on the units needs...
Bit error rate tests are done on recorded playbacks, so that I dont just send you a machine that plays video; because the machine employs 'forward error correction' in the recorded digital video ..
meaning you can have a machine that is barely working with lots of errors, but still plays back fine..
And we dont want this: we want to return a machine that is robust with lots of margin and very little bit error.
Ed
[email protected]
1helpful
Torque setting
Front 63 Nm Rear 72 Nm
Top Roland Computers & Internet Experts
Larry Ng
Larry Ng
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Roland Computer and Internet Expert? Answer questions, earn points and help others
