SanDisk Sansa Clip MP3 Player Logo
Shawna Gay Thompson Posted on Jun 03, 2009
My computer does not recognise it and it wont turn
My computer does not recognise the sansa clip and it wont turn on when its removed from the computer. i cant view anything on it nor can i listen to any music.
  • Shawna Gay Thompson Jun 05, 2009
    gosh!!!!!!!!! its either i dont know how to do this or im doing something wrong cauz it ain't working.
Anonymous
Level 1:
Scholar:
  • Contributor 51 Answers
  • Posted on Jun 04, 2009
Anonymous
Contributor
Level 1:
Scholar:
Answers
51
Questions
Helped
21659
Points
82
Click here to get your device turned on....
if your device is still not being detected in My Computer, Click Here for instructions
My sansa 4gb clip is not recognised by my computer. The computer will not acknowlege the usb either... My sansa has run out of battery. What can I do????
Hai, i have sansa clip 2gb with the same problem. one ultimate answer i got is Sansa clip uses Media Transfer Protocol(MTP). Sandisk(maker of salsa clip) know about the problem which cannot be solved(the earlier sansa products are to be avoided). There is no solution with the company.
My brandnew sansa clip is recognised by my
you should update new firmware first at http://forums.sandisk.com/sansa/
if it still doesn't work, change another one.
Good luck
1helpful
My computer will not recognise SanDisk Clip
See if you can download the driver for it on Sandisks site, this should make it possible for your computer to recognize it. You may also want to try a different usb cord, USB cords go faulty quite easily.
1helpful
My sansa clip ipod is not recognised by any computer
On your sansa, go to "Settings" then System Settings" then "USB Mode," then change it to MSC, if that does not work, try the other modes, just n case.
Hope this helps!
Computer won't reconize my sandisk mp3 player
Hi, just had the same problem after restoring my system.
You must disconnect and update your Windows Media Player to Number 11. My reinstall left me at WMP 9 and it wouldn't recognise my Clip. Go to the Windows website, follow the download instructions, and you should be fine. When you plug in the Sansa Clip or MP3, it should recognise it right away. Hope this helps!
Connecting Problem
Unplug your Sansa. Uninstall all the Sansa software from your computer, and reinstall the clean version from the Sandisk website. Then, replug the Sansa.
-Tha Mp3 Doctor
3helpful
2answers
Sansa clip installation
What you need to do is update your Windows Media Player. I believe it has to be WMP10 and higher. Let me know if that works. Oh and you also need at least Windows XP Service Pack 2. so update your windows software
1helpful
2answers
My computer wont recognize my mp3
I know this is only part of the solution:
- turn off your sansa clip
- put the slide button on hold
- press the centered button while connecting the sansa clip to your pc
the sansa clip will now be visible as a removable disk under 'my computer' :-)
I don't yet know how to proceed from here on
Sansa clip mp3 player
check drivers in xp or windows
do u have drivers cd ,
download drivers n install it.
ur's kishore chowdary +919441133420
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
