SOURCE: system error indicated paper in output tray to be removed
I would unplug the machine and start back up.
Besides that you can take a canned air can and blow around the area where the paper comes out. Esp around the back. This is either a dirty sensor or a sensor flag that is hanging up or out of position.
SOURCE: The ip4500 will not print - says the paper output tray is open!
Just fixed this problem on mine. Need to remove the covers, watch these 2 vids to see how..
http://www.youtube.com/profile?user=martop49#p/u/1/iQdHDR6po80
Then
on the right side where the on switch is, near the hinge is a little
switch with 2 yellow wires, it's probably broke. Pull the 2 wires out
and solder or twist them together, then put everything back together.
It will now assume the door is always open. Jobs a good'n :)
SOURCE: paper jam in output tray is displayed but i cannot solve
The way most printers know their output tray is full is by a little flag that passes by a sensor. Look for a little piece of plactic that should be hanging right by where the paper comes out. It is flag is not hanging then it must be **** and it is reading output full. Hope this helps.
SOURCE: my copier keeps showing an
on the output tray you will see sensor flapper... it can get stuck ed... try to manually lift or down it, it usually gets out of his holder.
Keep me posted,
Hope that help's!
CAUTION: Remove paper from the tray as carefully as possible. If any torn pieces of paper remain inside the printer, more paper jams are likely to occur, and this could damage the print mechanism.
Grasp the front of the output tray located beneath the control panel. Remove the output tray by lifting the front of the tray up and pulling the tray out. Set the output tray aside.
Read more: How to Load Paper into an HP Officejet All-in-One Printer ' eHow.com http://www.ehow.com/how_4489317_load-paper-hp-officejet-allinone.html#ixzz2NjlQ4lhl
