Sounds like you need to re-install your os win xp w7 w8 its what we call rolling where the boot up gets to a certain point then forgets what to do so it just keeps going around and around hope that helps.
SOURCE: my computer boots up but the screen goes black
its yuor grafic card its not good you need a new card.*** pedro aguiar lisboa portugual some probleme sen-me a mail for enderess [email protected]
SOURCE: e machine computer. starts up then it goes to the
This is caused by two files that are corrupt on your system. If you can get to another XP computer and get the following two files from the windows\system32 folder and copy them to the same location on your hard drive. The easiest way is to connect your hard drive to the other computer as a slave and copy them.
The files are: userinit.exe and wsaupdater.exe
Hope this helps
SOURCE: Black screen on my desktop, and connect pins are broken & bent
You'll get either no signal or missing color(s) if pins are bent or missing.
Carefully bend pins back with small needle-nose pliers. Pin 9 is missing by default - if any other pins are missing or broken, you'll need an expert to wire a new VGA plug.
SOURCE: Cannot boot from recovery cd's on El1200 emachine.
Found an emachines procedure here:
http://www.emachines.com/faq/vista/7515418su539.html
Hope this helps.
SOURCE: I have the EL1333G-01w emachine and would like to
yes you can upgrade your PC
folow the Site
http://www.walmart.com/ip/eMachines-320-GB-EL1333G-01w/13352324#ProductDetail
i dont have a windows 7 disc is there another way to fix it
