I have at&t 5700 phone but the language is chinese.i am unable to change it to english. kindly mention steps to change language to english.
SOURCE: language has to be changed
Press menu... Open Settings (you have to do this looking at the icons), select the 3rd (this is your phone settings) from the top, again select the 3rd (this is your language) from the list, and scroll up and down to locate the English. If you can't follow this, please let me know the model and brand name, i'll give you the code to change the language to english. Good luck. Thanks for using FixYa.
SOURCE: hiphone - change language from chinese to english
While there are youtube clips for some HiPhone versions, mine only had 4 options in settings.
I found a fix for mine at http://www.hiphonepro.com/how-to-set-language-to-english-step-by-step-t72-15.html?highlight=factory reset english
I had to register to access the site.
Check the post by GrootWitBass - it worked for me.
Hope it helps
Hi,1st take back up of data then do Hardreset after that when u will Start ur Mobile it will ask for Language then u can change it or Try to change the language form start>program and for manaul of the DOPOD visit the site of the mobile
Gizmo1
