2004 hyundai getz 1.1 . When driving the car a loud humming noise appears , it doesnt get any quieter when turning left or right or when depressing the clutch .No noise when car is stationary . Wheel bearings ? or something else
SOURCE: steering creeks when turning left or right. front wheel noise.
humming noise is bearing.creaking is either tie rod or other ball joint.tie rods on these go out all the time.bearing also
SOURCE: 2001 Chevrolet Cavalier front End Roar
You must replace wheel bearings in pairs to avoid loading the old bearing and, in time ruining your new bearing hub it is possible that you have already damaged the new hub
SOURCE: 2004 Hyundai Getz Noise in front
had same problem,believe it or not it was only a loose clamp on my cat- converter. jack her up and see hopefully same prob
