Black wire has come away from its junction inside the machine - not on the 'board' that you connect the power cable to. I think it may need to be soldered to a terminal near the screw to the rear of the machine on the opposite side to the control knob but cannot be sure. Can any advise, send a picture or a copy of the service manual please. Many thanks.
SOURCE: Kenwood chef A701A capacitor and other components
The 0.1 microfarad can be safely replaced with a 275 VAC 0.1mF mains capacitor. You can remove the clip that held the old electrolytic capacitor by sliding the old capacitor out and squeeezing the metal clip so that it disengages with the plastic base. The load resistor is 450 Ohm 15W or 20W wirewound. There is a 56 ohm resistor in series with the capacitor which helps smooth the speed change and reduces wear on the contacts. A 2W wirewound resistor works best. (It is worth removing the contacts and removing any pitting or carbon build up with fime emery paper). I have repaired about 20 speed controls sucessfully with these components.
SOURCE: Kenwood Chef A701A Blender needs new shaft seal
It uses a different thread = turn clockwise to undo - not the normal turn ccw to undo and the nut is attached to the 2 blades.
SOURCE: Circuit/wiring diagram for KENWOOD CHEF - Model A701A
Hi BGR1,
Can you also email the wiring diagram to me please. My email address is [email protected]. Thanks alot.
Bernard
SOURCE: Drawing of Kenwood Chef A701A
Can someone email me service manual please? [email protected] thanks in advance
