Televison & Video Logo
Posted on Oct 24, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TV antenna problem
My tv antenna was newly installed. /all channels are fine except Channel 10. Channel 10 is very blury. Is any way to fix the problem?
Peter
  • peter9 Oct 24, 2007
    This is a major channel that I cannot ignore it. Also my neighbor has no problem at all with this channel.
    Best regards
    Peter
Anonymous
Level 2:
Novelist:
Champion:
  • Expert 244 Answers
  • Posted on Oct 24, 2007
Anonymous
Expert
Level 2:
Novelist:
Champion:
Answers
244
Questions
6
Helped
104451
Points
454
Hi peter9,
It is possible channel bad reception is come from the signal of the tv channel not on your antenna. Just forget channel 10.
Best regards,
Philip
I'm trying to install my newly bought Insigna TV and it cannot get the channel I'm using EZ digital Antenna
Hey okay so you got this new TV and you have what's called an errand it's not a cable antenna it's called an air antenna so you need to go into the settings menu and after you hook up the antenna in position in your house somewhere then you need to go into the menu on the TV and settings and go to where the TV would normally use cable and change the setting to air after you do that you need to do what's called the channel scan with takes like 10 minutes and then after that you will be able to watch TV can I help you hey what's up
3answers
I have a new hdtv antenna and my hdtv gets all the local channels except 8. The direction from my house is 171 and that is also channel 4. I get 4 fine but not 8. what's up?
hello,
There would be weak signal reception at your antenna so it can't get the other channel. So change the antenna direction. If there's no result then increase your antennas hieght means keep your antenna at higher position.
Regards,
Laxman
When connected to cable box will not let cable box change channels with tv on but with tv off cable box works fine
Cable box not changing channels on VIZIO TV - Comcast Help and ...
forums.xfinity.com/.../Cable-box-not-changing-channels...TV/.../164607...
Apr 3, 2013 - I was able to connect my cable box and activate it without an issue. ... My problem lies in that the cable box will not change channels. Channel 8 comes in ..... I just unplugged the DTA ( you already did) and I let it sit for a while. No Audio with cable tv
Nov 15, 2012
remote not working cable box
Oct 13, 2012
Cable box not responding to remote (sporadic)
May 29, 2012
Remote doesn't want to work for the cable box
Oct 19, 2011
More results from forums.xfinity.com
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Mar 10, 2015 - If you are connecting your cable or satellite box using an HDMI cordyou will ... You just need to change the input of your TV then scan for channels. ... Except the Vizio TV will not receive a channel that all the other TVs get.
2answers
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
• You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
• If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
• If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
• To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
• Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Using an over the air antenna I get all channels but one.
I experience the same thing on a day to day basis. The key, is location of the antenna. Depending on where your antenna is located, determines if u can recieve local CBS analog v. digitial. I actually tried sticking aluminum foil to my old rabbit ear antenna legs. to my surprise, I even picked up digital channel I never knew existed. Besides, when the signal transmit in Digital, u are already prepared. Your local CBS afilliate station will be accesable on maybe 2 or 3 channels. example:
Channel 10 analog
Channel 10-1, 10-2, 10-3 digital HD will all broadcast the same programming.
hope this helps u out.
59helpful
9answers
Can't change channel using the remote or buttons on tv
Simple Fix
I had the same problem, couldn't change the channels with the remote or on the side of the TV. This was for a Vizio 37"
Here is the fix:
1. Turn on TV
2. With remote, press the Menu Button
3. Go to Antenna Menu
4. Select Auto Search
Let it search, it could take several minutes. It may not finish to 100%, mine got stuck at 79% for 10 minutes. It's fine if that happens, go ahead and cancel.
5. It should be done, your remote will work perfect along with the TV channel buttons.
GE TV/VCR 1995
Have you tried retuning for ch 10? Is your TV on the same antenna/ connection as the rest in the house?
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
