Some selections for the control panel don't work. Only a couple of selections are OK ( now we can only roast using the workable numbers). Also the light now stays on and will not turn off.
If this is simply grease and dirt build-up in the panel, can it be cleaned? If so, how do I remove the front panel cover to clean it?
Thanks
HI, unfortunately, it is not just dirt, this is a faulty touch pad that is combined with the control board. most touch pads are separate parts that are clipped in front of the circuit board but, in this case, the touch pad and control board are one piece. You will need to replace the entire control board in this case. the touch pad is faulty.
We have same unit and have had the exact same problem. reading from the customers' comment, I truly believe this is a design problem with the touch panel by Maytag. For ours, the touch button just went out one after another through a period of a year. We took it out last night and saw there is no fix of the panel. Will order a replacement but it is very expensive since you can only buy the whole panel. Terrible design!!!
I have a very similar oven from
Maytag. Had it for 1.5 years before it started to break down. The
initial problem was we lost the function of a couple of buttons on
the control panel. The cost to replace the control panel was about
$400.00 with about $250 for the part and the rest for labor. The
buttons weren't all too important (self cleaning, clock, warm) so we
kept using the oven instead of paying to have the part replaced.
Our repair guy is cool and tells me the
problem with the control panel is that Maytag didn't insulate the
computer boards so when you kick up the heat in the oven by using the
broil or self cleaning feature, you melt some of the contacts or
components. He says we can check appliance repair chat rooms for
more information. Sure enough, I found this problem occurs a lot for
Maytag. Man they must be making a killing off these parts. I agreed
to have my control panel replaced, but told my repair guy if it goes
out again, be prepared to install a non-Maytag oven. He gave me all
the dimensions of our oven cavity so I can pre-shop for a new oven.
we have the same unit and have been experiencing the exact same problem. reading from the customers' comment, I truly believe this is a design problem with the touch panel by Maytag. For ours, the touch button just went out one after another through a period of about a year. We took it out last night and saw there is no fix of it rather than replacing it. Will order a replacement today but it is very expensive since you can only buy the whole panel. Terrible design!!!
need to remove and install control panel in a Maytag Wall Oven
