buona sera cortesemente siccome è da molto che ho acquistato un telecomando universal urc22b e vorrei usarlo con una tv saba e non l’ho mai saputo usare, volevo chiedervi la cortesia di come poter utilizzare questo telecomando, se può mi può inviare l'istruzioni.
grazie distinti saluti
Doing some searching I came across this, I hope it helps.
From instruction booklet
Power on the control device or VCR and put the tape in.
Press on the SET key continuously,then press the device key you want to set.For example, TV1/2,or VCR1/2,or SAT/CBL or AUX.
Then the LED is on, release the key you press.
Press the SET key again and release it,then you will go into QUICK SEARCH MODE and the LED will flash all the time.
Press the POWER key once at the device,URC22B will send another POWER signal of the next code.(If VCR/AUX, you will press the POWER or PLAY key). Observe if the device works(POWER OFF or PLAY),if it works, go to next step , otherwise repeat the step
whenever you want to leave SEARCH MODE,please press the device key,(TV1/2,or VCR1/2,or SAT/CBL or AUX.) then the LED is off.
Then check other keys like [CH+/-],[VOL+/-] if they can be controlled.If cant be controlled,go back to the step
