Broken lens cover **RESUBMITTED to Corrected Camera Type**
The cover for the lens on this camera
is 4 small segments that slide back from the center of the lens when
the camera is turned on. Our toddler grabbed the closed camera, with
fingers on the lens cover, and 1 of the 2 larger segments broke off of
the cover. One of the 2 very small segments, located in the bottom
corner, that would normally slide off the lens with this missing
segment, remains on the lens when the camera is on. I think it's
possible that this piece broke off as well, and it's only jammed into
that corner, since it's positioned differently than its undamaged
counterpart. Bad idea to try removing that small piece? We had already begun plans
to upgrade to a digital slr when this happened, so I'm thinking we just
deal with a lens that isn't covered completely until we get the new one
in our hands.
Appreciate your thoughts, love the blog. Thank you!
Re: broken lens cover **RESUBMITTED to Corrected Camera...
It's not really a problem if the lens cover isnt there. The following actually shows how to repair a broken lens cover. But have a feeling yours may be damaged beyond repair, so the next option is removal of the shutters. Be careful that you don't get any of the rubbing alcohol that's spoken of in the following procedures on the lens itself.
I have this problem also with Fuji Z90 model. Problem is fixed and focus now working ok. Camera is fall down and after when camera was started giving sound click click from focus big motor and error on screen Focus error Focus ( lens ) was open ( small cover on top bellow sticker ) Small "snail" gear is taked out . Two sliding segment adjusted
for focus ( upper full up and lower full down - beware about spring inside below this focus pins )and snail is inserted back. Camera started and focus start
working. I need to make small adjustment . Reason when camera is
started picture is not clear and before using camera i need to do full
zoom in and back zoom out. After this picture is crystal clear and all
working ok.
Lens errors (zoom errors on Fuji's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
This normally happens when dirt or dust particles get caught between the lens segments. Check for this. If you can't do it yourself, take it to the nearest authorized service center.
I recently had the lens cover stick partly open. There are 4 segments to the lens cover, and if we number them from the top, number 2 was not closing. I gently flicked the segments a few times, in case there was a grain of dirt causing it to stick (although the camera has never been in a dirty or dusty environment). This caused the lens cover to close fully each time, but now it would not open fully, segment 1 would not open, although it would stay open if moved by finger. Anyway, after a bit of fiddling, I got it working properly again. The way that the lens cover appears to work is that only segments 2 and 3 are pushed open or shut by springs, segments 1 and 4 are pushed open and shut by tiny tabs that catch on segments 2 and 3. If the segments somehow get pushed out of alignment, then they either bind (causing the cover not to shut), or they get disconnected (causing the cover not to open fully. Now I am not sure exactly what I did to get the mechanism form the stuck open state to the not opening state, but from there the way to fix it is to: -With the lens open... - Hold segment 2 in the closed position with firm finger pressure (which will tend to push it towards the lens). - Push segment 1 towards the open position until you can see that it has cleared the edge of segment 2. - Lift segment 2 way from the lens so that it will rub past segment 1 as you... - Move segment 1 to the open position. - Repeat if necessary to get the technique right.
I can't provide any guarantees, and I am not about to repeat the excercise on my camera, but it was a lot easier than sending it off for repair.
I rednecked the crap out of mine. I pulled off the slide cover and placed a small piece of paper clip in the area of the copper to make a permanent contact. Then duct taped it secure and then cover the whole slide mechanism. I would not recommend this method but it worked.
Hello
This is a pretty usual type of problem. The lens assembly is composed of some lens and some servomotors that will move them around or focus them properly in order to get a sharp picture. This is a delicate part of any camera. Sometimes one of the small parts in the lens assembly get out from their positions and damages or jams other components there. Therefore when you start the camera it produces weird noises as it tries to extend the lens. A camera doesn't know where the lens are at the moment you start it. It will power up the motors for a small amount of time, as it knows that if the motor works for about 1-2 sec the lens should move and extend. If this doesn't happen the camera gets confused and gives you errors or makes strage noises as it powers on the motor but it can't move the lens because they got jamed or are fully extended.
Only a service center can fix this because lens mechanisms are very fragile and require specialised hardware to be realigned or repaired. In your case it would be adviceable to ask them an estimate of the repair, for you to know if it's worth it. It can be a simple job like putting back the piece that got out of place, but also it can be a situation in wich the whole lens assembly must be changed because of extensive damage recieved when the motor forced the lens to extend. It is also a good thing to do, NOT to power on the camera anymore as it can damage itself furthermore.
Sorry as I can't give you more detailed tips, this isn't the do-it-yourself type of repair, even the service centers are having problems with this repairs. Good luck however, maybe it's a simple thing.
In my case, there was dust in the switches that sense the cover movement.
Close the sliding door and wait until the lens is drown inside (timeout).
Open the screws that secure the front cover.
Remove the sliding door covering the lens. There is no trick (hidden screws etc) so just use the force. The door is mounted by two-sided tape and adhesive.
Remove the front cover. This is also mounted by two-sided tape / adhesive in the center, so you have to be a bit brave.
The sliding door rails and the movement sensors are now visible. Clean all dirt.
Try the door functionality.
Mount the front cover after the lens works as it should. Close the screws.
I will give this a try, thank you very much!
