Bucket full light is on but bucket is empty and bucket is securely in place. Also displays CH 01 in humidity display.
SOURCE: Dehumidifier Error?
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
SOURCE: My LG dehumidifier tries to
Here is a manual for your machine, in case you don't have one:
http://homeappliance.manualsonline.com/manuals/mfg/lg/lg_dehumidifier.html
You have to join and log in to the following site, but they claim to have 2 answers:
http://www.maybenow.com/LHD65EBL-Code-CH-01-q23864244
Here's what one person said about the code on webogdery.com:
Unit keeps saying bucket full with nothing in it and it will have a CH 01 code come up on the display. NO reference to it in manual. Call customer NO service and they say to take it to a repair shop 1 1/2 hour drive away. I would not recomend this unit to anyone unless you like to keep buying new ones every year or so.
Not good news, but someone said the unit has a 5 year warranty, so you might check into that.
Another person said check the sensors:
--Shoddy craftsmanship:
1. The sensor that stops the unit when the water reservoir is removed is flimsy, often it does not detect that the reservoir is inserted back, one has to fiddle with the reservoir till the sensor finally "catches on", but then every now and then the mechanism will lock and will be unable to detect that the reservoir is full, resulting in a water spill.
It doesn't seem like anyone has figured out this code, but it has to be a sensor, or bad part, if you can just figure it out.
Good luck, hope some of this helps, and thanks for using FixYa.
SOURCE: bucket full light blinks with
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
SOURCE: Not running- CH 24 code on
If the bucket is in place correctly, turn the unit OFF & unplug it for 10 minutes. This should allow the electronics to rest and revert back to the original factory setting after you plug it back in and turn it ON. From there you should be able reset the controls to your liking.
Hope this helped. Thanks for choosing FixYa.
SOURCE: dehumidifier model lhd459el bucket full
I had same problem but fortunatly had two units (one working other not) tried swapping capacitor / thermal switch with no luck, removed plug into circuit board for humidity sensor and bucket switch.now both units work, this tells me it was simply a bad connection of the board. hope this helps someone.
Here
show that the bucket is full when it is not.
Dehumidifier
heatman101
