How to connect samsung e251 to pc as a internet modem bluetooth
I have a samsung e251 mobile phone i want connect my mobile as a modem via bluetooth for internet my network operator is airtel i am already install samsung pc studio but i can't connect internet on my pc in my mobile gprs is already activated so how i can use internet on pc through my samsung mobile via bluetooth
Follow the below mentioned steps :
1.
Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
Launch Internet Sharing, found in the Start menu on your Samsung cell phone. Open the application.
Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than is showing on the display.
Start the Internet Sharing connection. On your Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
5
Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
Two methods are there to use your phone as modem 1)you can use your PC suit to use your phone as modem for You need
*USB cable or Bluetooth on your mobile
*PC suit software provide by phone manufacturer(ex:Nokia,Samsung,LG,Sony Ericsson).
To use your phone as modem *install the PC suit softwareConnect your phone to PC via USB cable(I recommend you to use USB because it's faster)
*Open PC suit and select "Connect to internet"
*if its failed you can use manual setting by selecting "Connect to internet">Select access point>select the name of network operator from the access point list(if you did't get your network operators name in the list you need to contact your network operators customer care they provide the access point name you need enter this access point in the manual updation list now it works.
2)You can use Bluetooth technology to connect to internet (2 methods are there)For this you need
*Bluetooth on your PC and phone To connect(in windows OS)
*Click on Bluetooth symbol on task bar
*Select add device select from device which can be connected to your PC list(set your Bluetooth device to visible all mode)
*Add your device to your PC Add completion of the above...
*Again click on Bluetooth symbol on task bar
*Select "show all devices"
*now select your device(one click) at this time 4 options appears on top your devices list
*select connect using>access point
and 2nd method is *Again click on bluetooth symbol on task bar
*Select "show all devices" *double click on your device
*select connect to internet from the dialog box which appears after selecting the your device Above options are with respect to Window 7 and Windows related operating system. Thank you...:) ANY SUGGESTIONS?
Samsung PC Suite - Internet through mobile modem -Error 619 - Data Cable
Rectifying the error
1. Samsung USB modem driver (Download from Samsung ' Local Link) 2. ConnectYour Samsung with a working Internet connection ( via )USB Cable 3. Samsung PC Studio or any other Samsung mobile drivers are not installed
Procedure
1. Connect your Samsung Star 3G to your PC and install the modem drivers that you have downloaded.
2. Goto Control Panel > Phone and Modem Options
3. Select the Modems tab. You will see Samsung mobile modem listed.
4. Select it and click on Properties.
5. Goto the Advanced tab and put the following in the box for Extra Initialization Commands:
+cgdcont=1,"IP","your_apn_name"
( or tye AT+CGDCONT=1, "IP', "apnname")
eg:- +cgdcont=1, "IP", "bsnlnet"
6. Hit OK and exit.
The next step is to create a dialler for your Samsung Star 3G mobile modem.
Error 619 solved
1. To create a dialler, Goto Control Panel>Network Connections
2. Hit Create a New Connection and proceed as follows (each sub-point is for each screen of the wizard):
2.1 Network Connection Type: Connect to the Internet 2.2 How do you want to connect to the Internet: Set up my connection manually 2.3 Select Connect using a dial-up modem 2.4 Select Modem-Samsung Mobile Modem 2.5 Type an ISP name according to your preference (could be anything) 2.6 Type*99# as the phone number ( or type *99*1*1# or *99***1# ) 2.7 Leave Username, Password and Confirm Password fields blank 2.8 Hit Finish
That would complete the wizard and make a dial-up connection for you. Dial it and you will be connected to the Internet via your Samsung Star 3G phone modem without using Samsung PC Studio
Hi there , It is possible to connect this phone (E1410) to the PC for Internet facility. You just need a bluetooth device. I have successfully done it on my Airtel sim card using MO (Mobile Office) package. Follow these steps- 1. Don't call the Airtel Customer Care to activate Mobile Office Setting. Because they will tell you that your handset does not support automatic MO setting. 2. In your phone go to browser and go to Browser Settings 3. Create a New Profile with the Name- Mobile Office 4. Home Page- http://www.google.com 5. Set the Proxy as- 202.56.231.117 6. Set the Port as- 9201 7. Bearer- GPRS 8. Go to Advanced Settings and type the APN- airtelgprs.com 9. Log in ID and password no need. 10. Recharge your your phone with any GPRS (Mobile Office) packages Rs.22 (200MB)/ Rs. 98 (2GB-30 Days validity). 12. From your mobile dial *567*11# (This is must) 13. Now your MO is activated. Now turn off your Phone, Remove the Sim card and turn on again. Please cancel the mCheque msg. if it appears after restarting your phone. 14. In your PC -Install the Bluetooth Driver. 15. Right click on the Internet Explorer-Properties-Connections 16. Select the Bluetooth DUN Connection 17. Click on Settings 18. Set the proxy-202.56.231.117 ;port as-9201 19. Click -OK, Apply - OK. 20. Now go to control pannel and double click on Phone and Modem options. 21. Click on Modems tab. 22. Select Bluetooth DUN Modem 23. Click on Properties 24. Click on Advanced Tab 25. In the Extra Initialization Command box paste the following command line- AT+CGDCONT=1,"ip","airtelgprs.com","",0,0 26. Click OK, then Apply-OK. 27. In your phone turn on the Bluetooth 28. Insert your Bluetooth Device in Your PC and connect Your phone through the Bluetooth software 29. Click- Bluetooth Dial up Networking Service on your Bluetooth Software 30. The dialing number is *99# 31. Remember the connection may not done for the first time. So you may need to try more and more. Because the Airtel lines are always busy. Sometimes you may need to unplug your Bluetooth device and exit your BlueSoleil from the Quick Lunch bar and Restart the Procedure. Remember this is the only procedure for Airtel (MO) users. Try and Try and if it is connected the open any browser (I prefer- Mozilla Firefox) and open- www.google.com. Remember in some cases, it shows a false connection and the website will not open. In such cases, Disconnect your Dial Up connection and Re-connect it. If any message apper in you phone, then exit it. 32. To check Mobile Office Package balance and validity dial- *123*10# 32. Remember I am sending this information to the internet via Connecting my E1410 mobile to my PC using Bluetooth device. 33. If you are successful, please say a little word-"Thanks
S u can use ur samsung mob phone as a modem and connect internet in ur pc. use usb bluetooth dongle or usb data cable to connect ur phone to pc. either use pc suite or bluetooth software(Bluesolil) for connecting internet. Samsung e1410, samsung e250 etc are the models compatible
(I)
1)First pair the PC and your phone of course
2)After pairing, meaning the phone and the pc sees each other, go to your phone and look for the icon "internet sharing".
3)Choose bluetooth pan as you pc connection then press connect. So now your phone is on data connection via gprs, 3g or 3g+
4) Then go to your pc now and go to My bluetooth places search for Network Access Point and enable it. It will turn green with arrows, meaning it has established a connection.TADA! Now you have internet connection using your i780s
(II)
Do you have in your programs or settings a icon called Internet Sharing? If so please connect to active sync first and then select the internet sharing icon. Active sync will disconnect and your laptop will start using your phone as the modem.
what operating system is your pc please?
I want to get on the internet via EE service
