Noticed a small amount of water and rust around the seal. Can I repair this myself or should I send it in?
SOURCE: Pentax Optio A10 lcd replacement
Re PENTAX OPTIO A10 LCD Replacement I wish Mike Brunner would advise us where we can get a replacement LCD for $40, was it from a used camera?. A new one from PENTAX Part Number 76650-0500 Tel 1 800 877 0155 Is just under $60 plus $8 shipping in the USA but is currently out of stock. There is also a San Diego company with limited stock (5) that wants about $70. Removal of the LCD is relatively straight forward. First remove the battery and the card. Then unscrew some very minute philips screws and carfully remove the back cover. Separate the two halves of the cover with a thumbnail to unhook a snap connection after the screws have been removed. It's best not to remove the front cover so as to avoid damage or contamination of unrelated areas. To remove the LCD look for the retaining snaps and gently pry the left side ( camera facing forward and upright) back and lift the left side of LCD up and unhook the right side. The LCD will now still be attached by the multi wire strap and a minute two wire connector. Using tweezers on the plug and not the wires gently disconnect the two wire connector. The multi wire strap with about 25 miniscule gold connectors is held down on the mating contacts with a clear sticky tape. I was able to pull mine loose before I saw the sticky tape. To reinstall the replacement LCD a very good magnification of the 25 or so contacts may be required to correctly line up all the mating contacts on the back of the camera as there is no apparent mechanical means to correctly align this. There is no soldering required or practical at his connection. Use some clear sticky tape to hold it in position.After reconnecting the 2 wire plug the right way up and when the LCD is folded over back into position and snapped down into to the retension snaps,this should also apply gentle presure to the 25 pin connector. Adding a very thin layer of non conductive material over the 25 pin connector before snapping the LCD back might be helpfull in the longterm retension but too much compression will may fail the new LCD. ( Well that is what I'm going to do when I get my LCD) ( I may also put the battery and card back in and switch it on before replacing the rear cover taking care not to get an electrical shock through some accidental discharge, so don't do as I say unless you know what you are doing) Re assembling the rest should be straight forward. Then test the result. Note: The camera buff who encouraged me to do my own repair has added an extra layer of clear plastic over the exterior cover of the LCD to better protect it. It is also advisable to have a hard case or reinforce a small soft case with a used credit card to protect the LCD, so as not to have to repeat this again. Good Luck. From Santa Cruzer
SOURCE: Pentax Optio 555 - Fozen with the lens stuck-out
happened to me a couple times & after recharging battery, still stuck, so manually pushed it in when motor was running trying to close it.
SOURCE: Pentax Optio M30 won't turn on!
MY CAMERA WONT TURN ON... I HAVE CHARGED THE BATTERY SO I KNOW IT IS CHARGED...ANYONE HAVE THIS PROBLEM.?
CHERI
SOURCE: My pentax optio M30 turns off after it's on...
There is no fix for this you can do yourself. These cameras are designed to shut themselves off if there is any kind of an internal problem. So automatically shutting off is a symptom, rather than the problem itself. Return the camera to a Pentax repair centre. They'll give you an estimate, and I guess you'll know what to do if the cost of the repair turns out to be more than the camera is worth to you. And don't waste your money on advice from a "fixya.com" expert, cuz' they'll tell you the same thing, after asking if your battery is charged and if your SD card is in and if your internal memory is full, yada, yada, yada, which is ****, cuz' under those various circumstances, the camera would stay on, at least for a couple of minutes.
SOURCE: How to unlock card in pentax optio Says Card
Hello
OK, if the memory card itself is locked, you might
sometimes get this error code. All you need to do is to take out the
memory card and switch the lever on the left side to the unlock.
If
the error is still displayed after you did the above, you might want to
try the card in another camera.
If
the card works in another camera . the problem is with your card reader
in your camera.
If you open you sd slot and look inside with a
sharp light , you should be able to see on the left side of the slot
there is a little copper or spring steel lever switch. This switch work
as follows:
1. When no card is inserted / no write protection ,
the switch is open and thus the protection is off.
2. When locked
card is inserted , the tab is depressed and tells the camera that the
card is lock.
Contrary to popular belief ,the little tab on the
sd card is not an electronic switch and does not physically influence
the card operation itself. If you put a locked card into a camera
without a sd lock switch , you would still be able to use the card
normally.
It is incredible difficult to fix this switch because
of space limitations in the sd card. Look into the sd slot and if you
can see the switch , use a needle to pull the little tab down toward the
base of the camera by about 2mm or until it works being careful not to
bend it.
If this does not resolve your problem , there might be a
short in the switch circuit and the camera will need to be disassembled
to resolve this error. This should cost no more than $50.
Please
feel free to contact me if you need further information
Kind
regards
Andrea
