Just had my dishwasher plumbed in getting an E1 error message, water pressure has been tested. Any ideas?
SOURCE: E1 error on LG - LD-4120M
E1 is a common error in the LG Dishwasher range and is usually caused by the failure of the circulation pump and/or the impeller.
The motor and impeller are a complete unit.
Often what happens is the impeller breaks on the motor shaft and doesn't spin, therefore doesn't pump water.
There is a pressure sensor which indicates the lack of pressure and shuts the machine down with the E1 error being displayed.
The lack of pressure can also be from a water leak (as the owners manual suggests) also a controller PCB fault may produce an E1 error, however, the pump problem is extremely common.
Unfortunately, I have had 5 pumps die in 4 years and my dishwasher is only used about 4 times a week.
SOURCE: wont go on to programme when switched on starts
Check that you have tuned on the inlet water tap(faucet usa).
SOURCE: Lamona dishwasher from Howdens. E1 code
we have a howdens dishwasher model number hja8630, which is full of water which hasnt drained . i have ladled it out checked filters are unblocked but it still fails to start. it does a click click sound and then nothing . only 18 months old and only ever used twice a week
SOURCE: E1 ALARM ON KENWOOD DISHWASHER
An E1 is a control board error. Sometimes it can be soldered at the heat element relay which get hot often and can melt the solder ion the board. It is fairly easy to replace a control board.
SOURCE: Hi Kenwood dishwasher kdw60x10 -
I have the same problem :( e1 fault and full of water, I have check pressure and drain for blockages too.
E1 error is "water supply" related. It might be water pressure or pressure switch issue
Is your water supply (in) in the off position? Your in hose is kinked?
