My LG Dishwasher that has no heating element is not cleaning properly. I have changed detergents - more, less, vinegar, everything I can think of and still get cloudy plastic and even seemed to ruin a glass measuring cup that is now cloudy? HELP!!!!!! I do not have soft water in our city, but do have filtration and Pelican system for natural softening.
Check the following to address this issue you are having..
1. No water
Make sure you get water to the dishwasher. Check to see if the water
shut-off valve (located under the sink) is open. If you get water to
the dishwasher, but there is still no water inside during the fill
cycle, the problem might be with a faulty water valve (located at
the bottom of the dishwasher, behind the kick panel, on either
side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This
could be caused by a partially closed water shut-off valve (located
under the sink), or a faulty dishwasher water valve (located at the
bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher.
Make sure there is no debris blocking the holes inside each spray
arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees
Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to
both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the
dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
There are a few out there, I recommend a solution called Dishwasher Magic.
Hard water is the reason for the spots. There is a new product out at www.dishwasherfilter.com that is made specifically to fix this problem. It filters the water going only into your dishwasher leaving your dishes spot free with every load. It is very affordable and guaranteed to work or your money back. You will love the way your dishes look after the very first load.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
I
Dishwasher
Spray
Arms not Spinning
How
to Buy Appliance
Parts Online
A
dishwashers...
Element not Working
Dishwasher
Maintenance
Dishwasher
heatman101
Dishwasher heating element replacement
heatman101
zzty
