If it went dead almost
immediately after pressing the Start pad, that's usually a shorted
high-voltage capacitor.
If it went dead
several seconds after pressing the Start pad, that's usually a
failing
high-voltage transformer.
If
it goes dead or blows the house fuse or breaker (or GFI) when you plug it in or open
or close
the door, then there's a problem with a door switch or door switch
mount.
If it's intermittent or
random, it may be a bad
connection, usually on the control board or a loose fuse holder, or
even an intermittent fuse.
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven here.
Here's a YouTube video
available showing how to remove a typical over the range control panel assembly
in under 5 minutes.
We're happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
Hi .. your problem is most likeliy inside the microwave itself. I would replace it. Or you can take it to a shop that does repairs to get a diagnoses and estimate .. but replacement might be the less costly.
check fuse inside unit microwave has a fuse around 15 to 25 amps get at local hard ware store u should discharge capacitor before installing fuse not nessary in microwave
if there is no plate to unscrew in front of the bulb , then the only way it can be changed is to open the microwave
WARNING: HIGH VOLTAGE CAPACITOR INSIDE WILL STILL BE HOLDING HIGH VOLTAGE
if you are not familiar with this then don't attempt the repair!
then you will need a technician
