The display on the color remote has progressively turned darker to the point that it can not be seen outside in the sunlight. How can the disply brightness be increased?
Hello ksolovy, i understood your Problem with the Sony KP-53V90 53 in. Rear Projection Television,In fact i encountered already that kind of problem you have it now. Check first the color wheel im sure that the blue section of your color wheel was burned and the blue color turn to dark; That's why you have seen dark picture, Re-place color wheel.
Hello First thing you need to do is,inside where you can see the screen, search for the brightness and contrast options in your cameras menu. Once you know where they are go outside and try to tweak it until it works. Usually you would want a higher brightness, then just adjust the contrast until your satisfied.
Hi Steve,
The picture is darker because the dust build up on the lamps or CRTs. I would suggest to leave the TV unplug overnight and clean the lamps using a screen cleaner that works better then windex and clean the mirror that reflects the video to the screen if you can get access to it.
first turn your color all way off or down.try turning your contrast way down as far as it will go you should see a darker picture. now bring up the brightness to a point half way. bring the contrast up to see grays and whites and blacks...adjust brightness more if need be. now you should see a nice black and white picture. no bring your color up last ...not saturate but to your liking. if you stilll got problems i bet your video out transistor is shorted....meaning shop work.
