? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
Hello Sagar,
green led means tv powered on and status ok.
Red blinking light almost always means defect, overcurrent or overload.
6 blinks for Sony lcd flat tv means trouble in backlight circuit, or backlight inverter (backlight illumination or lighting makes your tv screen visible).
common problems in the inverter circuit, which drives the backlight, or shorted drivers, or short-circuit transformers or open circuits. You should find the problem in the inverter circuit, or in the power supply board or in the main board.
Also look for bad capacitors (electrolytic caps) which are bulged and swollen on top.
Decoupling plugs from printed circuit boards can help you in finding the problem board by elimination method.
If you power up the set after unplugging certain plugs on f.e. the inverter board , this could result in getting a green power led and concluding that this board is faulty.
The set is is shutdown as something is wrong. The problem here is it can be power supply or another area in the set. Take it to a shop for an estimate.
the problem is in the power supply(they know about it good luck fighting them)but there is good news.you can remove the power supply and replace electrolytic caps,EC18,EC19,EC20 all of them are 1000mf at16 volt use 1000mf at25 volt.you can also go to shopjimmy.com enter model number you will see power supply part number MLT169B
it will be cheaper for you to replace the caps,the board cost about $80.00 from them
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
if you are comfortable taking the back cover off, do it and visually inspect a cylindrical shaped components on the power supply unit... if you can send a picture please do [email protected]
