Kodak EasyShare V1003 Digital Camera Logo
Posted on Jun 02, 2009
Cracked screen my kodak easy share v1003 was droped and the screen is craked under the surface...other than that is works perfectly... and yes it takes great pictures..just cant see what i'm shooting ..is it worth getting the screen replaced??? can i do it??
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Jun 03, 2009
Anonymous
Contributor
Level 1:
Answers
22
Questions
Helped
6856
Points
66
No the screen is not worth gettin fixed the lcd scrren usaually cost more than the camera itself does but if your camera is discont get it fixed because their will be no other camera like it
4helpful
How to reset a kodak v1003
my v1003 camera is saying reset switch on memory card. I can not take any pictures at this point and I don't see instructions in my Easy Share manual. I'm on my way out of town it is 6:28am and my camera won't work. can someone please help me. thank you
E.J
[email protected]
1helpful
I was downloading my pictures from my kodak easy share v1003 to the easy share program. the camera was recognized the downloading showed up as downloading to a file foler by date. it finished downloading,...
I?ll be fine. All your original pictures are on the C drive. Unless you have changed the directory onto which you save when transferring: You can find the pictures under C-Drive, my pictures. The camera might need to be recharged. The camera doesn't charge from the computer while transferring pics. You will need to switch the camera off before the camera will start charging.
1helpful
Can't get easyshare to start download
If this fault message is on your computer starting Easy Share Software: Please do a Clean Install on the software:
Please follow the instructions:
  1. Uninstall Easy Share software:
    1. Select Start > Settings > Control Panel > Add / Remove Programs.
      For Windows XP operating systems, select Start > Control Panel > Add / Remove Programs.
    2. Select Kodak Easy Share software.
    3. Select Remove (or select Change, and then select Remove).
  2. Run the Clear utility:
    1. Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear
    2. Click the Download button, and then follow the on-screen prompts.
  3. After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
2helpful
2answers
Kodak Easy Share V1003 -Screen stays a grey blue color.
A new screen is availably from virtualvillage dot com for about $45. I replaced one last week. It only takes 20 minutes and a small screwdriver. The ribbon cable is held in by a flip up lock at the main board.
2helpful
Kodak Easy Share V1003 camera is frozen. Turned
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. Before you pay for expensive repairs that you may or may not need, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Lcd cracked and bleeding spot down left part of screen
Go to www.kodak.com look for the customer service link or look for contact us ,then call and they will give you a return number
Hope this was of help!
What is the upper limit of SD card as GB without any freezing or slowrunning problem in Kodak easy share V1003?
I have a 2 GB SD card that i use on mine, and i dont seem to have any problems with the camera being slow. I hope this helps and good luck!
Kodak easy share v1003 with broken lcd how i can fix this cheap
Sirs I have a Kodak easy share v1003 showing the screen completely white. How can I replace it... seems that I already find the spare part in e-bay. Can I do this replacement by mayself?
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
