Question about Car Audio & Video
BUTCHERED WIRING. I aquired this system in my new caravan, but it had been fitted by a butcher using a chainsaw I think! I have identified the speaker wires but could do with an assist for the rest.
  • blueextc3221
    blueextc3221 May 11, 2010
    Please post year - as most years are different.
    Thanks!!
Try taking a 12v light take solid black and touch to one terminal only on light. now takeone of the remaing wires and touch to othe terminals until light comes on this is your memory wire. now turn on ignition and repeat process leaving out memory wire and this is your hot wire
i solved my problem this way, you dont need all the other wires unless you have apower a antenna
Posted on Jun 07, 2009
  • 87 Answers
Dont know what year you have but one of these will work. Ground is usually separate in Dodges:
1990 Dodge Caravan Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Yellow
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Tail Gate
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
1997 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Red/White
Car Radio Illumination Wire: Black/Yellow
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Blue/Orange
2003 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Gray/Red
Car Radio Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Chassis Or Metal Strap
Car Radio Illumination Wire: Orange/Tan
Car Stereo Amp Trigger Wire: Gray/Green
Left Front Speaker Negative Wire (-): Green/Black
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Gray/Black
Left Rear Speaker Positive Wire (+): Green/Black
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Gray/Black
Right Rear Speaker Negative Wire (-): Gray/Pink
Posted on Jun 03, 2009
Anonymous
SOURCE:
I have a Clark fork lift with a grey Holden motor. It needs a new clutch. I think someone has butchered it. Has anyone got a manual or pictures of the correct couch and pressure plate.
go to Clark fork lift service shop and ask for a parts break down for that engine combination
The pressure plate should be the standard plate to fit that flywheel but the clutch plate may have a bigger hub section for the transmission input shaft. Either way they will be able to advise of the clutch kit part number
Sep 28, 2018 | Holden Cars & Trucks
My boyfriend is fixing my 1999 dodge durango ac heater blower can you splice the wires to the new blower
There is no need to splice anything
You buy the correct replacement part
& plug it in
How could he possibly work on any vehicle
& then not know about splicing,soldering,etc,
if that ever came up
If someone butchered the vehicles wiring, return it
to as built factory condition,that may require some
salvage yard wiring connector & splicing, as you call it
Aug 31, 2013 | 1999 Dodge Durango
Stock wiring diagram for 1993 fxr
Hi Anonymous, for a free wiring diagram please visit the website below. Good luck and have nice day.
Harley Davidson Wiring Diagrams and Schematics
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 06, 2012 | Harley Davidson FXR Super Glide...
Have just bought a Fiat punto 2001 and the wiring for the radio has been butchered, how can i solve this
If you are installing an aftermaket deck then it will come with a new harness which you can solder into the old one and clean things up. If you have a lacking confidence with electrical wiring then you can take it to a car audio installer and they should be able to repair it for you.
Cheers
Dave
Mar 19, 2011 | Car Audio & Video
Vodafone are having probelms fitting a hands free
hi
normally nissan use a 1 or 2 plug loom, as long as noboby has butchered it to fit aftermarket radio, shouldny have a problem getting a loom. try daltac.co.uk.
hope this helps
Feb 19, 2010 | 2003 Nissan Altima
We have a 1976 ford f150 351 windsor the wiring has been butchered and it keeps blowing the im. what do we need to look for?
2when you install the im do you apply the heat dispersing grease? Heat is what damages them..
Sep 13, 2009 | Ford F-150 Cars & Trucks
86 celica radio wiring
I can help you...
Here are the correct wiring colours and their usage:
GREY: Power IN from the 7.5 amp RADIO #2 fuse (Hot with key ON)
LIGHT BLUE with a YELLOW Tracer: Power IN from the 15 amp RADIO #1 fuse (Hot all of the time)
PINK: LF Speaker +
VIOLET: LF Speaker -
LIGHT GREEN: RH Speaker +
BLUE: RH Speaker -
BLACK: LR Speaker +
YELLOW: LR Speaker -
RED: RR Speaker +
WHITE: RR Speaker -
BROWN: Ground/Earth.
This sdhould get you up & going; hope it helps; and THANKS for choosing FixYa!
Oct 27, 2008 | 1986 Toyota Celica
1978 F250 Ranger (Lariat)
I was able to Google a complete wiring diagram for my '79 F-150
Oct 10, 2008 | 1981 Ford F 150
Car Audio & Video Logo
1,091 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Mark Skinner
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
