Yes, a faulty water level pressure sensor can cause a washing machine to get stuck at the rinsing cycle and not drain. The water level pressure sensor is responsible for detecting the water level in the washing machine tub and signaling the control board to activate the drain pump to remove the water. If the pressure sensor is faulty and cannot detect the water level, it may not signal the control board to activate the drain pump, causing the washing machine to get stuck in the rinsing cycle.
To troubleshoot this issue, you can try the following steps:
- Turn off the washing machine and unplug it from the power source.
- Locate the water level pressure sensor, which is typically located on the side of the washing machine tub.
- Check the wiring and connections to make sure they are secure and not damaged.
- Use a multimeter to test the continuity of the water level pressure sensor. If the sensor is faulty, it will need to be replaced.
- If the sensor appears to be working properly, check the drain pump and hoses for clogs or obstructions.
- Reconnect the washing machine and run a cycle to see if the issue has been resolved.
If you are unsure about performing any of these steps or if the issue persists, it is recommended to contact a qualified technician for assistance.
