Nokia Handsfree For 6020, 6101, 6102 Headset Logo
A
Anonymous Posted on Jan 25, 2014
Earpiece jumper - Nokia Handsfree For 6020, 6101, 6102 Headset
Headset earpiece assembly has become detached from headband assembly. The post does not want to go back into the hole on the earpiece assembly bracket. What do I do?
The headband post can only be inserted into the earpiece when the earpiece has been sufficiently rotated. (Note that the hole and post are a 'D' shape, not round.) The installed ear cushion is preventing you from rotating the earpiece sufficiently.
Remove the ear cushion from the earpiece by carefully pulling it off so you do not damage the clips that hold it on or the gasket material between the cushion and the earpiece. There are six clips, three on each side.
Now you can rotate the earpiece into the position where the headband post can be inserted into the earpiece.
Carefully reinstall the ear cushion by pressing it onto the plastic clips. Note that it can only be installed one way with the internal plastic support towards the headband.
tip
C905 - Cant hear, earpiece problem.
This is a little tip for anyone having problems with their Sony Ericsson C905 where they cant hear anything whilst on the phone.
This is only if you cant hear anything through the earpiece, however it works normally when you have it on Loudspeaker...
There is a fault with the C905 ribbon flex, this flex connects to the phones, keypad and then runs under the screen and has pads for the phones earpiece to connect to.
There are 3 methods of solving the problem
1, If your phone is under warranty have an authorised Sony Ericsson service centre repair your phone for you, this is FREE and is the best option.
2, You can buy a replacement ribbon, for these handsets and change it yourself. It looks like the image in the following link
<a href="http://www.findmethatphone.co.uk/fixes/c905flex.jpg" target="_blank">C905 Flex</a>
3, If you are able to solder and feel confident you can try the following fix, you need to make a jumper from the right solder pad to the leg on the transistor just below, use low res wire and be very carefull...
Remember trying 2 or 3 on your handset, if your phone is still under warranty will end up voiding your warranty so only do this if you dont have a warranty...
Nokia e63 headset mode
Hello I think that you could not fix this problem by yourself because there might be some sort with the Earpiece IC (filter).This problem can only be fixed by mobile tech by removing the ic and applying two jumper...Or by changing the earpiece socket.So, my advise is to visit nearest mobile repairing shop.Thanks for visiting fixya
I have music on my nokia express music phone 5310, but it wont play through the headphones. It is new headphones. Help I am going crazy!
Even If the headphone is new and it does not work, there might be internal hardware problem.You need to contact mobile repairing shop.If the earpiece filter is damage we need to change / make jumper.Good luck
2helpful
Can I connect my garmin nuvi 1310T to my Jabra BT2070 bluetooth headset earpiece
You probably cannot. Some bluetooth devices act like phones, and others act like earpieces. The Garmin acts like an earpiece to offer a hands-free speakerphone while driving. Your Jabra earpiece wants to pair with a phone, not other earpiece-type device.
Apr 18, 2011 • Garmin GPS
1helpful
2answers
Nokia 1208 earpiece problem
Hi, Earpiece can get damaged if there is dirt or the earpiece is totally damaged.
You can clean up the earpiece and see if it will work, if it doesn't work, you will need to replace it.
Thanks for using fixya.
4helpful
4answers
Nokia 1208 earpiece ok but ringer is not working
if you can changed the ringer speaker inside then do ti.. because it is just the problem on it..
5helpful
Cant hear out of earpiece, only speaker
two possible causes. either your earpiece is faulty or the flex cable is faulty. because the earpiece is on the upper side, it is linked through the flex cable and if there is a cut on the flex cable, then that may affect the earpiece lines. also, poor contact of the earpiece may cause that. open unit, ensure the earpiece has contact, check the earpiece itself and finally the flex cable.
Regards
5helpful
Nokia 6020 Earpiece jumper seting
i don't know why you need make it jumper to earpieces, if you one of PTT user likes Malaysian people, it's so simple, open your box of your hand free, directly solder 1 wire from negative lead of Mic and shot to negative lead of earphone.
Vote me if this instruction solve your problem. :p
My phone only works with the earpiece or speaker
the Motorola phone your talking about is not specified.First the problem can be solved.
It is an earpiece problem.The earpiece it faulty and it needs a replacement.
NOTE:
Some Motorola phones earpiece is attached to the flex of the phone, while some as an earpiece, which the flex is it can still be fixed.
Mar 15, 2010 • Cell Phones
Top Nokia Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
