Cars & Trucks Logo
Posted on Jun 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dash lighting and tail light.
The dash lighting is out and- what do you call this light? the tail light that stays on when you are driving... all the other lights are fine. turn signal, reverse, brakes, headlights ok etc... ok. i checked and replaced fuses and lights... well not the dash lighting... any suggestions?
Anonymous
Level 2:
Sergeant:
  • Expert 179 Answers
  • Posted on Jun 02, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
179
Questions
0
Helped
73332
Points
590
The bulb in the dash went out you need to remove cluster panel near where the light went out
MY Park lights and dash board wont come on
Check your fuses first, park lights, I think. Pull the light switch to first click and check if your front park lights are on. If no lights are on, the headlight switch is probably bad. If the fronts work, but no tail lights or dash lights, the problem is probably a wiring problem under the dash. The same wire to the rear tail lights is usually with a splice to the dash illumination lights.
1992 corona engine light, battery light and taillight lights on dash stay on while driving, anyone know why?
The battery light would mean the alternator is not charging the battery, the engine light is either a check engine light for the computer or low oil pressure (red) and the tail lamp warning is for a bulb not working.
2002 corolla tail lights dash lights not working
change your dimmer light switch and check the "tail" fuse
I have head and brake light but no tail and dash board light
I have a 1993 grand marquis n all my lights come except the taillights no blown bulbs check all d fuses no bad ones can I just get a good answer to my problem
My dash bored wont stay lite at night with my lights on in my 1992 Buick
There are few help links provided to resolve this issue of dash board light not working.Click the link below to go through its procedure:-----Dash board lights not working? http://repairhelpcenter.blogspot.in/2012/02/dash-board-lights-not-working-on-gmc.html
----------- light in the dash blinks? http://repairhelpcenter.blogspot.com/2012/01/overdrive-light-in-dash-blinks.html
-----------Orange O/D warning light flashing on dash? http://repairhelpcenter.blogspot.com/2012/01/orange-od-warning-light-flashing-on.html
---------gauge on the dash quit working on? http://technoanswers.blogspot.com/2012/01/temperature-gauge-on-dash-quit-working.html---------No 4x4 light on dash? http://repairhelpcenter.blogspot.com/2011/12/no-4x4-light-on-dash.html
----------Digital Dash Display not working? http://schematicsdiagram.blogspot.com/2011/12/cadillac-seville-digital-dash-display.html
---------warning on dash and alarm sounds? http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html
---------Light Stays On dash of car? http://schematicsdiagram.blogspot.com/2011/06/brake-indicator-light-stays-on-dash-of.html
----------The ABS and Traction Control Lights stays ON dash of car? http://schematicsdiagram.blogspot.com/2011/06/abs-and-traction-control-lights-stays.html
----------warning lights remains steady on dash? http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
---------light bulb under dash replacement?
http://schematicsdiagram.blogspot.com/2011/12/heating-knob-light-bulb-under-dash.html
Parking lights, tail lights and dash lights not working? http://technoanswers.blogspot.com/2012/01/parking-lightstail-lights-and-dash.html
How to replace Instrument panel and dashboard?
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-instrument-panel-and.html
Tail lights and dash light fuse keeps blowing? http://technoanswers.blogspot.in/2012/02/tail-lights-and-dash-light-fuse-keeps.html
This will help.
Thanks.
89 mustang lx ( My dash lights stay on for approx 2 minutes before the 5 amp fuse pops) Any idea ?
you have another circuit piggybackin on the dash lights, my guess is a bad ground to the parking or tail lights, try unplugging the tail lights and front marker lights. if the fuse satys good you have it
1helpful
E brake light in dash
Check your brake fluid level.If thats low then your light will come on and go off with the car moving the fluid about.
Tail lights and dash lights
You'll have to read through your owners manual. For some time Auto makers have been putting your taillights on the same fuse as your dash lights as an automatic indicator that they are out. I would read through your owners manual and decided where and what fuse will supply power to the taillights and dash lights. If indeed all fuses in connection with the dash lights are good I would suspect the automatic starter.
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
