Need one don't have it canon power shot sx510hs
SOURCE: +driver for canon powershot a 40 on vista
I had same problem. Called Canon and found out A40 is not compatible with Vista so there is no driver. But you can download pics to your Vista by purchasing USB Memory Card Reader/Writer you can find at Walmart for about $12.00. You put your Flash card in device and has USB that plugs in computer for downloading pics.
SOURCE: Canon PowerShot S2 IS 5.0 Megapixel manual
Click Canon Support to download user manual of S2 IS camera.
Thanks.
Testimonial: "Thanks so much!"
SOURCE: canon powershot SD1200IS user manual
Go to the support section of the Canon website to download a copy to your computer.
SOURCE: How do I display date and time for Canon Power Shot?
The date stamp only works in "Postcard" resolution. Press the "Func Set" button, then scroll down to the bottom to select postcard resolution. Then press the menu button. Select the "Camera" menu, then scroll down to the the Date Time Stamp selection to turn it on.
SOURCE: Canon Powershot SX10is All my action shots in
you should set it to a high shutter speed and f/stop also set your pictures to a RAW setting, if that made no sences let me know, and i'll say it abit more simple :)
