Based off what you have described the settings on your Frigidaire range do not light up and you would like to know the location of fuses. There are no fuses within your range, if the control panel is not lighting up it could be a short within your panel and that may need to be replaced. I would recommend having a professional technician out to disassemble your range and replace any electrical components. This will protect you from any personal injury and future issues with your range. Hopefully this information is helpful. -Matt
You need to hold /push the oven control knob in quite firmly while you press the igniter. When it lights up keep holding for about ten seconds then gently release it.
You don\'t need to remove the top. The thermostat is the long skinny tube in the oven that comes up to the railcock behind the oven control knob, remove the front panel to get the railcock/thermostat out which has the tube attached to it.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Buy a new stove element. If you open the stove look in the back. It should be black. It might have a crack or be clearly broken. This is a cheap fix. If you want to be sure that it is working at the connection unplug the element and pull it out. Put a volt meter into the prongs. Turn stove on and see if its putting out voltage.
The control panel must be on and in manual mode for the oven to work. Turn the power off for a moment and then back on. If the panel starts to flash, set the time and set it to manual and the oven should work. If the panel does not light up it is faulty and requires replacement.
Thanks for using FixYa. Error code F1 means a bad Electronic Range control (ERC) and to resolve this issue you’ll have to replace the Electronic range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
