Kenmore built-in Microwave needs to be replaced because it has stopped working. Model # 721.62463201, Serial #407 TA01786. Manufactored July of 2004. Is a replacemet available for sale? Where, and how much?
SOURCE: kenmore microwave range hood model 665.61612100 manufactured 2001
The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid. This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller. This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on. If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
SOURCE: Underneath Light funtion stopped working on Kenmore 62642 model
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: need to replace light inside kenmore microwave
Unplug the unit first.
To install the halogen lamp WB08X10050 you will need to take the cover off. You can see a diagram at;
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=36363693302&productCategoryId=0123370&brandId=0583&modelName=MICROWAVE&diagramPageId=00006&componentDescription=INTERIOR%20PARTS%20(2)&documentId=S9060341&backToLink=Return%20to%20Sub%20Components%20list
then click on "view full size"
This will give a view of the parts. Only remove the parts needed to get to the bulb.
There is a fuse inside the oven. The rating of the fuse may be 8amps. It is not suggested to run the oven without load inside.
SOURCE: F-9 Error on Kenmore Ultrawave Microwave Model 721.64682300
From everything I have read it is a 1100w inverter, I am having the same problem.
