Was cooking and turned it off, went to turn it back on and wouldn't turn one and display for oven is also out. checked breaker and everything is on. just happened all at once. help??
SOURCE: Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
