Check your manual for the "System" of needle
a normal sewing machine needle has a "System" or dimension
called 15x1 or 705 H. That indicates the length, the circumference
etc. If the needle you received with the machine is the same length as the above system then you should be ok. Also most often the needle package for most machines will be labeled "Universal"
It was not that easy to find the manual so I understand why you came to us for help. After some serious sesarching and forum reading courtesy of Google, I found your manual here:
