The more I look at it I think it's oUt2 which according to the instructions should be fixed by removing and reinstalling the batteries. That didn't work.The more I look at it I think it's oUt2 which according to the instructions should be fixed by removing and reinstalling the batteries. That didn't work.
You can't post conmments that contain an email address.
I have not yet found a manual for the Ozeri ZK15 food scale online on a site I consider is safe for downloading (meaning: I don't consider the sites I have found safe from malware being downloaded along with a PDF manual.)
Therefore, if you have not already done so, I suggest you contact Customer Support for Ozeri and ask about the availability of a manual for your model of scale.
go to bluetooth menu on iphone. delete all zk s9s there. Make sure the zk is not already connected to your ipad. Only one live connection is allowed at the same time.
network errors, like the 15-03, that you are receiving, have to do with fax "forwarding". the errors are thrown because the proper destination, or setup of the destination, for the forwarded faxes, are incorrect.
personally, i have not seen any 15-whatever codes. all the codes that i have dealt with are 14-01, 14-09, and 14-33. please double check the code that you are getting, and check the settings on copier.
14-01 and 14-09 codes usually mean that the smtp server name is incorrect, or the administrator e-mail address has not been added to the setup of the machine. although, it is still possible to e-mail directly without the administrator address being programmed. fax forwarding canNOT work without it. hence, the codes.
14-33 code usually means that there is an issue with the folder destination that the machine is trying to send to.
