SOURCE: unlock home theater system samsung ht-x20
http://www.videohelp.com/dvdhacks/samsung-ht-x20/8981
This should solve it :) I had similar problems.
Swapnil
SOURCE: samsung ht-x20 unlock codes
This should solve it :) I had similar problem.
Swapnil
SOURCE: Sammi Jones must be an Indian spammer on FIXYA --- samsung HT x20 region code
For Samsung HT-X20 the region code unlock listed workd perfectly. Just hit 8,4,2,6,9 then ENTER (do this twice) and it will play your DVD which it did not before.
Abe
SOURCE: Problem with SAMSUNG HT-X20!!
The fan is going bad and when u play dvd's the spining of the cd is acting as a fan witch is why they play longer then any other mode i had the same problem 2 times the second time samsung wanted 160$!!! thats bull because it keeps going out so what u do is open the case and remove the cover over all the capaciters and whatnot and replace that fan in the back then cut a hole in the top of the metal case directly about the cap's that warm up and install a aditional fan to act as a chimney a little noisy but i did this and the player had been runing in aux and radio mode for a few days stright now no problems at all it's alot of work and skill but for 2 5-15 dolar fans sure beats the 160 for repair or buying a new recever!
SOURCE: Samsung HT-X20 disc tray won't open
while unit is unplugged, try holding down the power button on the main unit for 10 seconds.
Hope this helps!
