Heating & Cooling Logo
Posted on Jun 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PILOT LIGHT WILL NOT LIGHT
I HAVE A LAARS LITE 2 POOL HEATER OUTDOORS I,VE COME TO LIGHT IT AFTER THE WINTER AND I CANNOT GET THE PILOT LIGHT TO LIGHT THERES A SPARK FROM THE IGNITION AND I CAN HEAR AND SMELL GAS WHEN THE WHITE BUTTON IS PRESSED DOWN CAN ANYONE HELP PLEASE
lawrence montambault
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 81 Answers
  • Posted on Oct 07, 2013
Expert
Level 2:
Mentor:
Answers
81
Questions
0
Helped
56968
Points
150
Make sure enough gas is coming thru the piolet orface for the flame to touch the thermocouple. you may need to clean out the pipe that feeds the piolet orface and clean (make sure you can see light thru the piolet orface hole so that gas can come thru) with enough pressure to have the flame touch the thermocouple.
small spiders like to get into these places and spin webs and sometimes a blast of compressed air will clear out the poilet gas feed pipe & get you going again.
Anonymous
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Jan 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
9573
Points
40
The thermocouple not only keeps the pilot on but lets the gas valve know its okay to open on a call for heat, remove your thermocouple and clean it with a fine grit sandpaper and if this doesn't work replace it all together.
How turn on pilot on teledyne laars series 2
turn gas valve to pilot hold down for 1 minute keep holdibg and light pilot hold for 2 minutes then turn to on
Every year I have a problem getting it to light. The pilot is lit but the heater will not turn on. It is 8 years old and I have been having trouble with it since day one. My pool guy comes out fires it up...
First, check the gas valve and make sure the valve in all the way to "on" not "pilot".After shutting to off for the winter, and not turning the valve all the way on start up could be it. If that is ok, check/replace the pilot generator next to the pilot lite. One question. Does the pilot go out soon after calling for heat? Next, if you have it on "spa" or "pool" on the temperature adjusting module, try the other setting. eg. If it is on "pool", switch the knob to "spa" and adjust the temperature.
Pilot light on but heater will not start
check the high-limit switches. Under the inlet/outlet header. if either is open it will not allow you to fire up. my 150 degree switch was corroded and after jump9ng out, bam it worked.
1helpful
Laars Lite 2 - Turns off after 5mins of being on!
This happened to me and the tech came out and change the pressure switch and it worked fine afterwards
Top Lite On Heating & Cooling Experts
Paul Carew
ZJ Limited
ZJ Limited
john h
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
