This will be a good source of info for Yamaha outboards: http://www.marineengine.com/boat-forum/forumdisplay.php?37-Yamaha-Outboard-Forum
Yamaha Outboard Forum
SOURCE: Need cylinder and cylinder head torque specifications 98 XR 250
you dont need torque specs on that just use a 1/2 inch drive with you 14mm or16mm socket hold the wratchet right at the top and tighten it as tight as you could get it like that then use wratchet in normal position and just give it a little snugg it will be perfect i have done it a million time on the same type of bikes...
SOURCE: need torque specs
Lower crank 75 ft-lb Head 105 ft-lb No specific torque on connecting rods. Just dont over crank it. Thanks for using Fixya.com
SOURCE: oil spec .for a 1996 Yamaha 350 big bear
hi buddy use {silkolene comp gear oil 10w-90} or you can use {silkolene pro srg 75w} this oil is more race use either is good quality not cheap oil good luck buddy
