SOURCE: Cant connect usb mini adapter/ hid data stopped working error
Hi, My Name is Henry. I am one of the technicians here.
What windows are you using?
Please do not forget to rate my solutions to you.
Regards
Henry
http://www.clickpcrepair.com
SOURCE: USB device not recognized
From your description above it seems the problem is not with the USB as other devices are functioning correctly.
The main cause may be the Device drivers for the printer, the device drivers may get corrupted, make sure you have the latest drivers, download the latest drivers from the manufacturers site and install the driver first before attaching the printer cable to the PC/Laptop.
SOURCE: hp color laserjet 2605dn don't print correctly
surely,mirror laser scanner is so dirty,call expert for service cleaning.
SOURCE: HP Color LaserJet 2605dn is ready - but folder
it is problem your printer driver is not properly install or data cable is unpluged
SOURCE: HP Printer Usb port in my Acer Laptop , shortcircuits my house
hello
Try using external USB HUB (POWERED) Adapter. It might fix this issue.
Use an other USB cable and see.
If the problem still exist do not plug in the printer again, you may damage your USB port or even burn your laptop motherboard.
hope this helped
TekSpotDotCoDotUK
Testimonial: "Thanxs"
