Might the driver software was not properly installed. Or the settings of your audio and mic has something to do with it. Or try to goo to device manager, look for the specific device, then try to disable and then enable it back.
If the person cannot hear you then, either your microphone driver was not installed or not working OR the microphone is not configured in Skype. To test your microphone then click on Start - All Programs - Accessories - Entertainment - Sound recorder. Then record your voice and then play it back. If this is OK then the microphone need to be configured in Skype. To configure the microphone - Open Skype - Tools - Options - Audio Settings for the Microphone THEN click on Save.
Webcam Audio Getting sound to broadcast with streaming video using a webcam requires a few components to work in unison. Because most webcams do not have a microphone built in, you will need to buy a microphone for your computer or locate your microphone input if you have one built in (some laptops have these). The audio and video are two separate functions and must be diagnosed as such. b> Webcam Software b> If you have a webcam set up correctly and you are streaming video, then you are already halfway there. This details only how to make the sound work, so please refer to an article related to webcam video if you do not have that working already. The webcam audio and video both communicate with your computer via your webcam's software application. Due to this, you will find that there are settings specific to your webcam software for sound. Because there are various software applications that can act as an interface for your webcam, you will want to do a product-specific search on the Internet for your application's settings. Most often you will find the settings for sounds under Tools or Settings, then choosing Options or Preferences. Regardless of the application that you are using to broadcast your webcam video, you will need to ensure that your microphone is plugged into the "Microphone In" jack on your computer or laptop. The microphone input jack is commonly colored pink. b> Microphone Connection b> With your microphone plugged into the "Microphone In" audio jack, test the audio inside your webcam's software application. Most webcam applications allow you test your microphone by reading a sentence and watching a graph move as you speak. If you see this happening, then you have correctly hooked up your microphone. If you have a Windows PC you should also see if your computer recognizes your microphone by clicking on "Start" > "Settings" > "Control Panel" > "Sounds and Audio Devices." Under the "Audio" tab you will find a section for "Sound Recording." From there you can select or change your "Default Device." b> Hardware Troubleshooting b> In the event that your microphone is not recognized by your computer, continue hardware troubleshooting by contacting your computer's support staff. With a properly connected microphone and some minor adjustments in your webcam's software application, you should be broadcasting audio with your video in no time. Hope this helps.
well ..i cant see what type of conection you mic has and what you really want to achieve as far as quality of sound or ultimate use..,but...here are some ideas..
A mic needs a pre amp and that is often built into some cheap but usable mini mixers made by behringer..You could pick up one and a good cheap dynamic mic[dynamic mics are best close to the sound source] with a lead and then go from the main output of the little mixer to the audio input of the computer.. A second but easier way and one that could give very good results is purchase a USB input microphone and this will have mic pre amp built in so it just plugs into your computer usb port.. SE electronics ,Rode make brilliant ones that are used often for podcasting..[well worth the +-100 uk pounds] but i am confident that berhinger will make a usable model for much less money[these type usb condensers will be sensitive and give clear results]...
• Check all connections for the "(type of microphone)" , make sure the microphone switch is set to the microphone button.
• If you are running windows® 95 or later, check the microphone volume settings.
1. Go to the start button, All programs, Accessories, Entertainment(multimedia), then Volume control.
2. Make sure the microphone volume isn't set to mute. 3. go to options, then Properties..., select the button next to Recording 4. go to start button, All Programs, Accessories, Entertainment(multimedia), then click on Sound recorder to test your microphone.
Hope that helped!
~xiviogwiffi
Normal
0
Go to Control Panel and Click on Sounds, Click
on Audio, then Click on the Microphone. Then Click on the drop
down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
First, make sure you have a webcam with a microphone, and run any test software the webcam came with to check and make sure it is *supposed* to work. Next, open SOUND PROPERTIES through the CONTROL PANEL and then from the menu go to ADVANCED and RECORDING and OKAY, to bring up a volume array that includes the control MICROPHONE. Then, dig around to make sure MICROPHONE is the input being selected for amplification, and try ADVANCED on MICROPHONE and turn on BOOST if it has this control. You can test whether all of this worked by opening SOUND RECORDER from ACCESSORIES and making a short recording of yourself cursing the machine and everyone who designs them. If it plays back normally, try your web camera again. If it still has no sound, the problem is in the settings of the web camera itself. Open whatever software it came with and check setting like MUTE and MICROPHONE VOLUME are set correctly.
