Hi there, gently tilt the head of your machine back and rest it on the white peg thing at the back. Inside you should see lines on the back side of the oil pan...min and max. If you are somewhere in between, all good. If not, add more. NOTE: always use clear machine oil. Any other stuff will stain your work. Hope this helps, have a great day
SOURCE: problems when sewing over heavy jean hems
Are you using the correct type of needle? have a word with your needle supplier and explain the problem. Different threads and different thickness material need different top and bottom tension adjustments.
Can I suggest sew one thickness material at a time with tension adjustments for that thickness. Then change the tensions and do a batch of thicker material.
SOURCE: i need instruction and parts manual for juki
JUKI HOME SEWING DIVISION
8500 NW 17 th Street
Miami, FL 33126
Phone: (305) 594-0059
SOURCE: Juki DDL-5530 Sewing Machine Manual
go to www.juki.com.jp login industrial sewing machine and you can doenload manual for juki machine
SOURCE: is there a simple way to slow the speed down on a
On the motor where the clutch is you will see thge large pin with a nut on it, as you press on the pedal the pin engages with the motor, if you loosen the nut and unscrew the pin bit by bit and try the machine you will get to a point where you will have absolute control on the speed.
SOURCE: i need find manual for my juki ddl 8500
Go to the website freemanuals.com They may have yours
