SOURCE: cant get mp3 to turn on
check and see if the hold button is down, if so slide it to the off position. Reset the device by holding in the power button and the volume + button down for three 3 seconds. This will reset the device. also make sure that it is charged. If these do not work than you can contact philips on there website
Try holding in the volume + button and reconnecting it to your computer. Continue holding the volume + button in until the "found new hardware" wizard comes on. NOTE: if you hold the volume + in for longer than 1 minute and no hardware wizard appears, this strategy will not work with your version of Windows.
SOURCE: my philips gogear wont turn on
It could be a hardware issue requiring replacement, but here are the things you can try to narrow it down:
1. Make sure the hold/lock is not engaged
2. Reset the player
3. Run an Updated using the latest version of the Philips Device Manager from Philips website
4. Run a Repair in Philips Device Manager
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
SOURCE: I turn on my Philips MP3 player GoGear and it goes off!
are yaar.....there is a hold or keylock button just unlock that....
SOURCE: My Philips GoGear SA011 just
Back up your player before you format it. Formatting erases all the data inside your player.
If you don't see the Format option:
