Epson Stylus Pro 4800 InkJet Printer Logo
A
Anonymous Posted on Jan 24, 2014
Eject movement error - Epson Stylus Pro 4800 InkJet Printer
Error 3
Error code 3 is a mechanical falure code caused by dirty laser lens or, a build up on the mechanism which stops movement. Can possibly be cleaned with a can of compressed air and an alcohol swab.
21-1C1
Error 21-1C1 Failed to complete the reel position movement within the Cassette tape in specified time. will be ejected.
2helpful
Jvc dvd player won't open
when you hit the eject button try tapping the top above the disk drive. it may be somewhat stuck. if that doesnt fix it you might have a broken belt or a belt may have come off in it. the belt controls the movement of the drive in and out
My 2005 Chevy Malibu's 6 CD changer will not play CD's, and will not eject them either. When I press the eject button it appears to try and eject as I hear movement but after a short bit of clicks I get a...
Extreme heat can cause warping and the cd will not evenly eject or exit the slot. the player may have to be removed and the cd physically extracted from the player. Delco players have a lot of plastic cogs, flywheels and gears in them that get old and crack or split. Hence, the player can no longer spit out the CD.
6helpful
Jvc kd lx111 deck wont eject cd
I just had this problem today and when I attempted to eject the CD it would give me an error message that stated (ERR 32). Apparently this means that there is something blocking the movement of the screen, a little manipulation should help the issue. Another variable could be the Eject lock feature, essentially a "child lock" for your disc. When this lock is activated it prevents the CD in the deck to be ejected. You can change this by holding down the blue source button and the eject button simultaneously for about 2 or 3 seconds. A message should appear saying "No Eject" and one that repeatedly flashes "Eject on" These two things seemed to help me alot when I had this issue. If those things don't work I would recommend calling JVC, much to my suprise they were actually really helpful. Their number is 1-800-252-5722.
1helpful
4answers
Sony Handycam DCR-TRV22 camera
HI! THE ERROR CODE C:32:10 IS A TAPE LOADING ERROR. IS A TAPE STUCK IN THE CAMERA? IF IT IS OR NOT FOLLOW THE FOLLOWING INSTRUCTIONS TO CLEAR THE CODE!
1.UNPLUG THE AC CORD FROM CAMERA.
2.REMOVE FAT BATTERY.
3. REMOVE SLIM BATTERY, FROM UNDER THE LCD-ABOUT THE SIZE OF NICKEL.
4. WAIT 2 MINUTES.
5.PLUG THE AC TO THE CAMERA.
6. FLIP THE CAMERA TO THE VTR MODE.
7. TAPE SHOULD EJECT AND THE CODE SHOULD CLEAR.
OK? HOPE THIS SOLVES YOUR PROBLEM. DON'T KNOW IF THIS WAS ALL OF YOUR PROBLEM, BUT IT SHOULD SOLVE THE ERROR. IF YOU NEED HELP REPLY TO:
ARCLIGHT1217
I push the tape into the Vcr it tries to play it then it simply ejects it after about 5 seconds.
This is a safety feature of the machine. If it does not detect tape movement, the unit will shutdown and eject the tape.
Dan
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
