I have just replaced toner cartridges after not using the printer for a while. Whenever I print a page, I get black dots running down the right side of the page about 1 inch from the right edge. About 3 inches from the right side of the page, I have 2 black lines running like this - - down the page in line with the other dots. I have cleaned lasers, toner rollers and even used a laser cleaning sheet. No luck. Any thoughts? Here is a picture of a page I printed. Hopefully someone recognizes this problem! :) http://bit.ly/1dVxfxs Thanks!
SOURCE: Magicolor 2430 DL vertical white blank stripes
remove PC drum and under that you can see laser glass, clean it and reinstall.
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
