My camera is not recognized by my pc, I contacted nikon & they sent me the latest firmware update, installed it & still doesn't list it Any suggestions?
Any card over 4gb will not be read by older computers. If you don't have a newer computer the SD card reader, avliable at walmrt under $10.00 will work.
You are taking a much more complicated route than necessary. Don't connect the camera to the computer for downloads. Instead, buy an inexpensive (less than $20) SD flash memory USB card reader. Plug it into your computer, remove the SD memory card from your L810 and insert it in the card reader. The computer will recognize your SD card the same way it recognizes any memory device. All you need to do is drag and drop your pictures from the SD card to a folder on your hard drive.
SOURCE: My Nikon D300 doesn't recognize the 55-200 AF-S DX as a cpu lens.
you call the computer expert to your home and then tell him this thing. he will give you the full idea about it. from my side it is the camera body.
SOURCE: NIKON D80; Nikon 18- 135 G LENS, Camera doesn not recognise lens
try to clean the contact of the lens & camera
