I tried with and without clothes inside and situation is the same. Only for spining and remove the water from the clothes works fine, If I select a washing program it shuts down the power on the house
SOURCE: agitator not spining properly to pull clothes down into water
remove agitator cap remove boplastic cover underneath remove bolt remove upper portion of agitator replace agitator dogs part # 80040
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
SOURCE: hoover optima hnf6167 7kg washing
My washing machine completes its cycle but is leaking water from the left hand side on to the floor, Why is this???
n most washers the F01 error indicates an control board problem. It is like an internal program error.
A power glitch can cause the problem.
One of the things to try is to enter and run a diagnostic cycle, or unplug the machine for 30 mins.
