IBM Optical Scroll Mouse doesn't work (Device Driver Problem)
My mouse when connected to the laptop through USB port, the LED light glows. But it does not move the cursor nor any click button works. Any solution to repair the mouse IBM Optical Scroll USB mouse when connected to the laptop through USB port, the LED light glows. But it does not move the cursor nor any click button works. Any solution to repair the mouse? My laptop is SONY VAIO & operating system is windows VISTA and system asks for suitable device driver but there is no installation CD was given with the mouse or LAPTOP. Please help.
Mouse is working with other system, tested it already. If there is a problem in mouse IC, is it possible?Mouse is working with other system, tested it already. If there is a problem in mouse IC, is it possible?
You can't post conmments that contain an email address.
Re: IBM Optical Scroll Mouse doesn't work (Device Driver...
Connect your mouse. then restart your laptop do not remove mouse while restarting laptop. if not work after restart there is a problem in your mouse IC.
It may have a manufacturing defect. Have you tried it on another computer? If it works on another computer, see whether it works when connected to a different USB port on the laptop. If it does, then you may have a bad or damaged USB port on the laptop. If it works on another computer but still does not work on the laptop when connected through an alternate port, then see whether some other device will work when attached to the laptop's USB port. If neither the mouse nor the other device work when connected to a USB port, then you have a problem with the USB controller. If an alternate device does work when connected to the USB ports of the laptop, and if the mouse works when connected to another computer but does not work when connected to the laptop, then you have a software problem, and probably need to change the mouse driver in a control panel or setting in the operating system of your laptop.
it is only a USB mouse and works on any pC really.
w7 needs no special driver for this mouse ever,
it uses PnP, plug and play and the internet must be active and working for PnP to work is it? not told that.
your failed computer is all messed up with w7 even infected
monza is w7, 2012 made (year)
the usb ports are first not mouse the device manager must show all USB ports have good drivers, and you test them using a USB stick of thumbdrive memory to be sure they do work, and if does good
or use USB keyboard to test usb ports all
if all that works then the mouse is tried. and internet connected and the mouse to when connected must show up in device manager.
and actually function/
To setup a wireless mouse regardless of its type, do the following:
1. Insert the USB transmitter (this could look like a mini plug or a stick) and wait for windows to complete installation. 2. Once this is successful, turn on the mouse by holding down the power button. Or insert the disc that came with the mouse and run the installer. The installer will install the device drivers and setup your mouse's configuration panel which will reside in your system tray.
Make sure that the mouse has batteries and that it is switched on for it to work. It will glow red when it is switched on.
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver in make sure the battery is good ((has full charge))also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable) Windows 7 make sure you turn the mouse on depending on type/brand of mouse it will vary it could be a buuon or switch on top or bottom hope this helps
click start control panel administration tool computer managenent device manager scroll to mice and other pointing devices you might see a yellow question mark? right click to update drivers make sure the lead from the mouse has a secure seating and the lead is not bad/faulty (if applicable) make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable) click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot in xp hope this helps dont forget to vote
Here are some trouble shooting steps you can try relatively easily....
If the mouse connects via a USB cable, try connecting it on another USB port while the laptop is on.
If it is an optical mouse, check to see if the LED(s) underneath are lit. Change ports until LED lights.
If you have another computer also with a USB mouse and it is working, try a mouse exchange. If the non-working mouse also does not work on the other computer and the mouse from the other computer works on your Toshiba Satellite laptop, the problem is likely with the non-working mouse.
Finally, If the non-working mouse is a wireless one, its battery may be dead. Try a new battery in it.
see the very first thing is that what u can try is that try and connect the same mouse that u had and that had worked and if works then the prob is with the mouse that u have right now and if that also doesnt work then the usb port on the laptop has gone bad and u need to replace the motherboard of the computer but before replacing the motherboard try and connect some other usb device on the same usb port.........
Normal
0
Try disconnecting the Mouse Receiver from the
USB port and reinstall the CD software program. When
the program asks you to connect the MouseReceiver to the USB
port, do so and it should work.
Hope this helps. Bud
