Sharp AL-1655CS Copier Logo
A
Anonymous Posted on Jan 24, 2014
We replaced our toner cartridge and the red triangle light still flashes and the copier won't work.
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on May 29, 2008
SOURCE: Toner light on replaced toner
probably broken toner motorshaft remove toner cartridge look to back of machine if you find a white collar and a spring laying on the bottom thats it
checkitright
CheckitRight
  • 1363 Answers
  • Posted on Sep 17, 2008
SOURCE: red light
The triangle dots are "need toner"
the cylinder is "need new drum"
the jagged line W means "paper jam"
Everett Lin
  • 990 Answers
  • Posted on Dec 22, 2008
SOURCE: Red toner light flashing
Dear sir; CH appears on the window means somewhere the door didn't close, when you close all door the red light will be disappear. try it out and let me know if you need more help, good luck, DON'T FORGET GIVE ME A RATING, THANK YOU , HAVE A HAPPY HOLIDAY !!!
A
Anonymous
  • Posted on Feb 26, 2009
SOURCE: Sharp AL-1631 copier. Red flashing triangle no
Flashing triangle of dots? for your reference, this is, and always has been, the universal symbol for add toner.
...and here's your manual:
http://www.sharpusa.com/files/cop_man_AL1641CS_1631.pdf
Anonymous
  • 37 Answers
  • Posted on Feb 27, 2009
SOURCE: RED LIGHT
If the signs that is blinking red which is shape like triangle , it is the toner cartridge indicator. The toner cartridge is empty.Try to pullout and check the toner cartridge, if it is light in weight it is already empty.
2helpful
We can not find the manual on our Sharp AL-1631 copier. At first the light (shaped like a Z) came on to the left of the green button and we turned off the machine and now that light is off but a flashing...
The flashing red triangle which should look like a stack of dots is your toner cartridge empty indicator. You will need to replace the toner cartridge with a full one or have your existing one refilled. A manual for this discontinued machine will be difficult to find.
Good Luck and Thank You for using Fixya.
WheatlandServices
The red tringle light is on. What is wrong?
This triangle means that the toner supply is needed. It comes first as a steady triangle meaning toner is running low and eventually flashing triangle which means toner is completely empty and copy cannot run. There are two methods of replacing toner ;
Refilling and cartridge replacing.
  • You can refill by opening the waste container and then removing the lid on the unit. Use a sprout provided in Sharp Al1000 toner bottle or improvise by folding a paper into a funnel shape.
  • For cartridge , pullout the old cartridge and replace with a Sharp Al100td cartridge.
Nice time.
I have a red triangle flashing and the copier sounds like it is trying to warm up and then does nothing. what is going on?
Hi, this triangle means that the toner is empty. This can also be caused by a defective developer unit drive gears. Check that it is okay if not replace the gears. Replace the toner cartridge or refill the toner in its unit. Make sure you empty the waste on its side as it may cause some noise or toner spills. Use cartridge Sharp Al100td or refill with Sharp Al1000 toner bottle. All the best.
1helpful
Samsung 1915 printer: the red light with the double artrows and the exclamation in a triangle is flashing. What's up? John
1. A minor error has occurred and the machine is waiting for the error to be cleared. When the problem is cleared, the machine resumes.
or
2.Small amount of toner is left in the cartridge. The estimated cartridge life[a] of toner is close. Prepare a new cartridge for replacement. You may temporarily increase the printing quality by redistributing the toner.
Red light is flashing next to the triangle on my HP2600n laserjet. Do I have to replace all print cartridges that printer says are low
You only need to replace the light indicated toner cartridge but if the others are reading low be prepared to change them. You can do a supplies page printout from the printer menu, click on information and scroll down, this will tell you how much toner you have left in each cartridge
1helpful
Sharp AR-5316
The toner cartridge comes with on-chip sensor that counts the toner life. If you allow it to go empty completely that is it gives red triangle which is steady to warn that toner is near empty. You should replenish toner at this time but if you allow it to blink red triangle, that means its completely over and can't be refilled. REPLACE A NEW TONER CARTRIDGE.
My xc 1040 the little triangle keep flashing red and wont let me do anything else
Hello sir; The red triangle indicator light on, it means need toner, just replace toner cartridge shpuld be fine.
RED LIGHT
3answers
Paper feed problem
please check if the rubber roller that pulls the paper inside the machine check if it is clean because after long use this roller becomes so smooth ddue to dust and doesnt take in the paper , first clean it ,wipe with wet towel  try again
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
