HP Color LaserJet 3500 Printer Logo
Abel Xavier Posted on Oct 23, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dell laser printer m5200: 922 service fuser error how to solve this error?
  • jimmyd62 Feb 23, 2009
    I have a Dell M5200 Printer and am getting a 922 service fuser error. This happened after I installed a new fuser unit.
Anonymous
Level 2:
  • Expert 417 Answers
  • Posted on Jan 19, 2008
Anonymous
Expert
Level 2:
Answers
417
Questions
0
Helped
362274
Points
739
The fuser is not warming up replace fuser.
Thanks J
2helpful
3answers
My Dell printer is showing error 010-377. What are some suggestions?
http://www.google.com shows a number of possible steps. You may be faced with purchasing another printer, or paying for a fuser and service call.
Dell shows the following:
https://www.dell.com/support/article/us/en/19/sln155336/010-377-iot-fuser-failure-on-dell-colour-laser-printer-2150cn-2155cn?lang=en
How to replace fuser in Dell 1135N printer
Replacing The Main Service Part Of Fuser Unit - Dell 1135N ...
https://www.manualslib.com > ... > Service manual
Dell 1135N Manual Online: Replacing The Main Service Part Of Fuser Unit. 3.6.3.1 Spring-Es Separate it as take up the circle-area of Spring-Es from hook.
How to replace fuser in Dell 1135N printer - Fixya
https://www.fixya.com > support > t24863785-replace_...
Jul 23, 2014 - how to replace fuser in Dell 1135N printer how do you change the fuser - Dell 1135n AllInOne Laser Printer question.
20 Most Recent Dell 1135n AllInOne Laser Printer Questions ...
Nov 18, 2012
While install refil toner in Laser printer Dell 1135n - Fixya
Nov 19, 2019
My 1135n all in one won't recognize my local computer - Fixya
Nov 18, 2019
Dell 1130 Laser Printer 1130 fuser error #02-000 - Fixya
Aug 22, 2012
More results from www.fixya.com
Support for Dell 1135n Multifunction Mono Laser Printer
https://www.dell.com > Support > Product Support
Search Dell 1135n Multifunction Mono Laser Printer Support Information ... Troubleshoot Printer Spooler Errors, and Removing Printers from Windows Registry.
Replacing the fuser on Dell Laser printers (C2660dn ...
https://www.youtube.com > watch
PREVIEW
1:04 Watch this video to learn how to replace the fuser in your Dell C2660dn, C2665dnf, C3760n/dn and C3765dnf laser printer.
YouTube · Dell Support · Aug 15, 2014
2helpful
2answers
What does the 922.02 service fuser error mean? Will not print,
It means the fuser (roller than heats the toner to the page) has a problem, most like needs to be removed and cleaned or replace.
1helpful
The printer display says "Open Heat Error". What is this and what causes it?
I'm not real sure but I do know the the fuser area contains heat sensors. If the fuser temp is higher than it should be, you will get over-temp errors.
Get the printer serviced. It very well could be a motherboard failure or a fuser control card.
Don
5helpful
Dell printer will not print. Receiving message: fuser error
Fuser error usually means that the heater element has blown, or is not functioning properly.
The device will usually lock itself out to prevent any risk of overheating and causing a fire
You will need a technician to fix this
2helpful
925 service fuser error
A 925 Fuser Error indicates that the wrong fuser lamp or the incorrect fuser assembly is installed.
  1. If this error appears shortly after the fuser unit in the printer is replaced, put the old fuser unit back in.
    If the error message goes away with the old fuser unit, please check that the new fuser unit is the correct one for this printer model.
  2. If the printer has not recently had its fuser replaced, plug the printer directly into a wall outlet. Surge protectors and power strips can sometimes regulate the voltage to a fault for the printer. If the printer is already on a wall outlet, plugging the printer into a different outlet may solve the problem. Keep in mind that there is no need to have the printer connected to a computer during testing for a fuser error as any pages to test the functionality of the printer can be processed internally.
  3. If you have tried the printer on other wall outlets and the 925 Fuser Error still appears, the printer will require service to clear the message.
Dell 1110 Laser Printer Fuser Error after
I would if it will print I would try a laser printer cleaning kit canbe found at any office supply like office max or staples
6helpful
4answers
Fuser error
Hey, if your Dell 2335DN has a fuser error or low heat error first try cycling the power (powering off and back on the machine). If this doesn't fix it, you should replace the fuser (part# KW449). Here is a video showing how to replace it and where you can purchase one. Good luck!">
1helpful
2answers
Problem printing with Dell 3010cn Laser
Check for damage to the fuser located right were the paper exits. damaged fuser can cause lines
Dell 1600N Multifunction printer problem.
Fuser issues - if problem is reoccuring then you are looking at more expense, are all vents free of obstructions (folders leaning on machine sides/rear) is machine being flogged, is power supply consistent, maybe even fuser bought was faulty, many options, try doing a warranty claim on fuser or replace again, even better get another printer, welcome to our throw away world!
k24674
Grand Canyon Tech
Grand Canyon Tech
