SOURCE: I have problem with my HP business ink jet 2230.
hello sir, hi, the ink comes out from the ink cartridge to the ink cradle where the ink pass to the paper, this is clogged, need you to clean the ink cradle, you can use warm water to soften the dried ink.
SOURCE: HP Z6100- Magenta ink density fade
the printhead seat seal's may have worn/hardened and cracked/ or warped out of shape. If you feel confident to do so- remove the tube assy from the base front of the carriage( by removing ALL printheads removing the silver carriage cover and disconnecting the tube set from the carriage pcb) to reveal the Valve seats, remove the offending colours valve seat. strip the seat to individual component level and thoroughly clean ,testv the seal by squeezing between fingers and looking for cracks in the side wall of the seal.
