Could someone please post a manual for me or send it to me at [email protected] I cant figure it out It seems to be running but no heat blows out it does get hot though
Do you still have this heater? I'd be willing to take it off your hands. Actually, I'm in need of a pair of wheels for my Patton POH2501 and I can't seem to find them anywhere. Care to sell me the wheels?
Take a hole punch and knock a hole in each end, one on the top, one on the bottom and drain the oil into a 2 litre plastic bottle. Now you can recycle both!
Oil heaters produce no fumes or flames and feature whisper-quiet operation. Because the oil within the heater never needs to be replaced, oil-filled heaters are maintenance-free. In addition, these types of heaters are compact and portable - allowing you to carry them from room to room. Many also feature carrying handles or a set of casters for easy mobility
some of these types of heaters have a hole with a plug, that allow you to add oil, but few of these are in use today. so this being said it is most likely the heating element is failing to fully heat up the oil. parts may be found, if researched in detail on the net
also be known that the electrical componets are most likely to fail befor the oil evaporates. so look at all overheating controls and so on.
good luck,
