SOURCE: how to install an alpine cda 9851
you go to a stereo shop..(walmart autozone etc should also do) buy a mounting kit and a wire harness adapter. The wire colors on the adapter match the wire colors of most aftermarket decks. MAtch the wire colors and connect...make sure to tape wires well as if they touch you rick damage to your deck.. install the mount kit plug in your cd player and slide it in and you are good to go..
SOURCE: Volume issue with Alpine CDA-7839 and Soundstream Continuum
Interesting that you have a Soundstream "The Continuum" amplifier. This is limited edition of the Reference 705 amp produced with a polished aluminum (not chrome) case. You have a very hi quality - Old School - amp.
Properly installed this amp should produce more than ample volume levels and certainly far more than a stock unit.
Because the Alpine head unit provides sufficient voltage to drive the amp, it is likely either the wiring, or, the way you have it set up.
The amp has a large internal capacitor bank and for proper operation, this amp must be connected directly to your car battery, prefereably with 4 AWG. (The amp is made with 4 AWG power connections.) Use high quality speaker wire run directly from each speaker to the amp.
If you have done the above, then it is probably the way you have it set up. The amp is sophisticated with many configuration options. Do not change any switch settings while the amp is playing. Ensure you have the appropriate inputs and crossover selected. Check the gain settings.
SOURCE: Hello---We have the Alpine CDA-9830 MP3 Stereo. In
it sounds like you turned the internal amp off. you need to enter the menu and turn internal amp back on.
SOURCE: I have an Alpine CDA-7839 FM/AM CD Receiver.The
it probably has burned out bulbs behind the display.
