Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
Elvis Yang Ryan Posted on Jan 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Change TV resolutions to view slide shows
I want to view picture slideshows in a full screen mode, it says it's showing in full screen but it only takes up maybe half of the screen ...my pictures are like 1024*768... If I change my pictures to 1920*1080 then it will fill up the whole screen. Can I just change the TV to fit 1024*768 pictures? thanks
Lawrence Oravetz
Level 3:
  • Sharp Master 10,558 Answers
  • Posted on Dec 31, 2014
Lawrence Oravetz
Sharp Master
Level 3:
Answers
10558
Questions
Helped
2697284
Points
29284
Nope. The picture resolution has to be 1080 to fill the screen completely. Using stretch and zoom will distort the low rez pictures. No option to change resolution on the TV itself.
2answers
How do you make a disk of pictures whiling playing music
Beth
You didn't specify what OS you are using.
If it's OSX then it's easy using iTunes & iPhoto to select a group of photos and background music.
My slide show on my MacBook gets transferred to the Apple TV automatically and shows up on my Plasma 50" Screen.
Cheers
tip
Choppy image transitions when you view images by using the Slide Show
You experience choppy image transitions when you view images by using the Slide Show feature in Windows Vista and in Windows XP SP2 Windows Vista
1. Click Start , click Run , type regedit , and then click OK .
2. Locate and then click the following registry key:
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows Photo Gallery\SlideShow
3. On the Edit menu, point to New , and then click DWORD Value .
4. Type WinSATScore , and then press ENTER.
Right-click WinSATScore , click Modify , click Decimal , type the value that you want in the Value data
box, and then click OK .
Note To start the Slide Show feature by using different resolutions, type one of the following values in
the Value data box, as appropriate for your situation:
5
• For a resolution of 1200x1000 pixels, type 300 .
• For a resolution of 1600x1200 pixels, type 400 .
• For a full-screen resolution, type 500 .
Exit Registry Editor.
2answers
How do you set the background on a Dell to show a slideshow of all of the pictures?
To use your own pictures
1.
Find the pictures that you want to include in your slide show. All of the pictures must be located in the same folder.
Open Desktop Background by clicking the Start button Picture of the Start button and clicking Control Panel. In the search box, type desktop background, and then click Change desktop background.
2.
If the pictures that you want to use aren't in the list of desktop background pictures, click the Picture location list to view other categories, or click Browse to search your computer for the folder where the pictures are located.
Picture of the Picture location menuLook for pictures in other locations on your computer.
3.
Select the check box for each picture that you want to include in your slide show.
By default, all of the pictures in a folder are selected and will be part of the slide show. If you don't want all of the pictures in the folder to be included, do one of the following:
Clear the check box for each picture that you want to remove from the slide show.
Picture of one check box cleared in a group of selected photosClear the check box to remove a picture from the slide show.
Press the Ctrl key, and then click each picture that you want to remove. Only the selected pictures will appear in the slide show.
To create a slide show of pictures on the desktop, you must select more than one picture. If only one picture is selected, the slide show ends and the selected picture becomes the desktop background.
If all of the pictures in the folder are selected, any new pictures that you add to the folder will be added to the slide show automatically.
4.
Do one or more of the following:
Click an item in the Picture position list to crop the pictures to fill the screen, fit the pictures to the screen, stretch the pictures to fit the screen, tile the pictures, or center the pictures on the screen.
Click an item in the Change picture every list to choose how quickly the slide show changes pictures.
Select the Shuffle check box to have the pictures appear in a random order.
5.
Click Save changes.
To use pictures that Windows provides as part of a theme
1.
Open Personalization by clicking the Start button Picture of the Start button, and then clicking Control Panel. In the search box, type personalization, and then click Personalization.
2.
Under Aero Themes, click a theme to apply it to the desktop. With the exception of the Windows 7 theme, all of the Aero themes include a desktop background slide show.
3.
To change the theme's default slide show pictures or settings, click Desktop Background.
4.
By default, all of the pictures associated with a theme are selected and will be part of the slide show. To add pictures from other themes to your slide show, do one of the following:
Point to each picture that you want to add to the slide show, and then select its check box.
Picture of one check box cleared in a group of selected photosPoint to a picture, and then select its check box to add it to the slide show.
Press and hold the Ctrl key, and then click each of the pictures that you want to add. Only the selected pictures will appear in the slide show.
5.
To change the slide show's settings, do one or more of the following:
6.
Click Save changes.
Your slide show will be part of the unsaved theme that appears under My Themes.
For information about customizing and saving themes, see Create a theme.
You can find more themes to add to your collection in the Personalization Gallery on the Windows website.
For information about customizing a desktop background slide show, see Make changes to your desktop background slide show.
Cannot get full screen picture
Full screen resolution depends on the source signal that you feed to your LCD TV. Most often, the signal come in 16:9 screen size, which sometimes show big black portion on both top and bottom of screen. To maximizes screen display, you can adjust the screen size of your LCD TV through remote control, this features are available in most LCD TV. you will have the option to choose Full Screen Mode, 16:9 screen resolution or many others to choose from (most case about 3 to 4 screen size.
2answers
How to make a slide show on youtube?
Kindly visit the link below for a visual, step by step (easy to follow) instructions on how to make a slide show with pictures and background music, and upload it on youtube.
http://www.lostintechnology.com/software/how-to-create-a-slideshow-using-google-picasa
For you to complete these more easily and effortlessly, I would recommend to sort all the pictures that you want to include in the slide show and to choose the appropriate background music before you even start creating your slide show.
Enjoy, and Thanks for using FixYa.
In ma laapi i m not able to make a slide show help me
Put all the pictures you want in the slideshow into one folder.
To create a new folder just RIGHT MOUSE CLICK on an empty spot on your desktop, scroll down to the word NEW, then over to the word FOLDER and click on that.
The new folder will appear on your desktop and then you just name it whatever you want.
You can either drag your photos into that folder with the mouse or COPY and PASTE them there.
Now double click on the folder to open it up.
On the left hand side of the page under expand the PICTURE TASKS menu.
In there you will see an option to VIEW AS SLIDESHOW.
Click on that and your slideshow screen will appear and the slideshow will start playing.
The PLAY (start slideshow) button will be in the upper right hand corner.
The PAUSE, NEXT PICTURE, PREVIOUS PICTURE and the CLOSE SLIDESHOW SCREEN buttons will be up there too.
Good luck and please comment back and rate if this was helpful or if you need further assistance.
3helpful
2answers
How can I see a Microsoft Power Point slide show, size 3.30MB ?
Unless your picture frame supports Power point files you can't load it straight on to it, but you could try this.
  1. Open the powerpoint file in MS Powerpoint (or download the free powerpoint viewer)
  2. Use the Print Screen button (also marked PrtSc) to copy the screen to the clipboard
  3. Paste into a picture program (such as MS Paint, free with Windows)
  4. Save the files as a JPEG
  5. Load these onto the picture frame
Hope this helps
How do I rotate my vertical photos back to horizontal?
I don't think your camera has that facility[to rotate image]. As for a slide show you will have to upload the images into a computer to make a slide show- which requires new software-your computer may have some all ready on board- Then will have to be burned to a disk if you want to view it off computer- the camera is out of this equation now. Come back if you would like recommendation for slide show software
Why can't I run a Slideshow in Nikon View?
In order to display slideshows in Nikon View the Apple QuickTime software must be installed. QuickTime is installed from the Nikon View CD or can be downloaded, for free, from the Apple Computer web site: http://www.apple.com/quicktime/products/qt/ Quicktime is available for Windows 98, ME, 2000 and XP as well as Apple Mac OS 9 and X. If Apple QuickTime is not installed, when the "Slideshow" button is clicked the computer will "beep" and nothing else will happen. Installing QuickTime and restarting the computer will allow the show to display as desired.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
