Hi I'm using Jabra BT-2080 which is working perfectly fine with cell phones but when I connect it with my laptop (to use it with skype) it's drivers couldn't be installed on my laptop so tell me what should I do? Also lets suppose if this problem is solved then can I be able to use it as headphones I mean can I make it my default sound output source instead of laptop speakers? Anyway I'll be grateful if you reply back on [email protected] Thanks
SOURCE: Jabra BT350 stopped connecting
BR, I had the same problem with my BT350 and my Razr V3c. I was finally able to resolve the problem by doing the following:
- delete BT350 from device list on Razr
- start Razr looking for device
- put BT350 in pairing mode while phone searching (hold answer button till solid blue light)
- phone will detect BT350 and retrieve name
- select Jabra BT350
- say 'yes' to bond with Jabra BT350
- enter passkey - 0000
- phone will connect with Jabra BT350
SOURCE: Bluetooth ear set not being detected by new phone
ok, thanks.
Found the problem. As always "Read the instructions first!"
Bye
SOURCE: Unable to Detect the Jabra BT125 headset from any Bluetooth Device
If you hold down the button, it will turn the light blue, keep holding it till you can connect it. It will come up as Jabra BT125, hit connect. Then it will ask for a password. The password is 0000. Then it will connect :)
SOURCE: I'm trying to pair my jabra bt2080 with my ps3 and
This bt2080 is not work with ps3 because your ps3 bt is ftp profile and it ask for pass key and we can't enter passkey in bt2080
