I am trying to format my sd card the camers wont let me do it
A Fuji Finepix 2650 camera can't hold SD cards. It is made for xD picture cards only. I know there are adapters for xD camera's where you can put in a CD micro chip, but still Fuji won't give any guaranty this will work. And knowing the age go your camera, in such a adapter only SD micro cards would work and not the SDHC or SDXC micro cards.
If you do have a Kodak Z650 camera, your camera only can handle MMC and SD cards. If you bought a SDHC or a SDXC card it won't work. When there cards came out, some camera's could be upgraded with a new firmware, so they could handle the SDHC cards, but I can't find any firmware update for your camera.
There are some SD cards that go as high as 4 Gbyte, but most cards you now can buy from 2 Gbyte and up are SDHC.
Physical the cards look the same, but the addressing is different.
SOURCE: 8GB SD card not working in Fuji Camera
switch around the 8gb memory card
i had the same problem
SOURCE: finepix s700 says memory full and wont take more pictures with sd
i know this is late, but my camera had the same problem.
1. If you go in the setup menu.
2. Push the right button once and scroll down to the menu that says format.
3. It will ask you if you want to erase all data.
4. Select No and everything should be fine.
SOURCE: I cannot format cards in my Fuji S602 zoom.
Make sure your card is compatible for your camera, and or it is not defective. I know that with some camera models the card must meet specific specs. Consult your camera dealer or call Fuji photo support to verify if your card is compatible.
If you have the adabtor for your card to be used directly on your computer, you can see if formating your card with the computer will help. This is not the proper fix, but it may work for you.
Jerry G.
SOURCE: zoom, Menu/OK, up, left,right all don't work but
Try moving down, and then moving up. Similarly, try moving the opposing directions for left and right. If there is no way to go in a certain direction, on a certain screen, it will appear that the button isn't working. I think you can solve it now. I have faith in you.
SOURCE: fujifilm F650 Zoom Error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
